05-12-2020 07:34 AM
Hi Cisco Voice Experts,
In our On-Call Process from Cisco Unity Connection, when someone call our Help-desk Extension(5555) and Hit 9 it forwards to the on-call assign number. But once users hits 9, the external users shows the main company number(5900) not the real number from users cellphone number from external calls.
Do you know how to fix this in CUCM or Unity Connection?
Thank you in advance.
05-12-2020 11:24 AM
05-12-2020 12:06 PM
05-12-2020 12:40 PM
05-12-2020 01:21 PM
I would check in the egress gateway to see what you send as calling number to the PSTN service provider. If you send the calling party number, but you see the main number of your circuit on the called device it would likely be the telco that masks the caller id.
05-13-2020 05:15 AM
05-13-2020 05:26 AM - edited 05-13-2020 10:25 PM
As suggested you should check what you send to the Telco by looking at the SIP debugs and from the result of that make the decision if you'd need contact the Telco or not. However by what you say I would guess that it would be the likely next step.
05-12-2020 08:14 PM
05-13-2020 06:32 AM
05-13-2020 08:22 PM
05-14-2020 06:44 AM
Hi Sudaggar,
I cannot find it on "check Gateway/Route List --> select that end device (SIP trunk)" .
I went to Device> Trunk> Found SIP_To_GW > Then scroll down Found below. Is this what you are referring to?
See below Photo.
05-14-2020 08:10 PM
Thats correct.
Kindly change this to originator.
