External/Internal Calls don't work on New 2901 Router
ryasuda26
Cisco 2901 VoIP router with PVDM3-16= module, PVDM3-64= module, VWIC3-1MFT-T1/E1 card.  IOS 15.1(4)M4
We are replacing our 1760 router with this new 2901 router and the configs are the same.  When we dial out we here a busy tone and sometimes when dialing in there is also a busy tone.  See attached files.  I am not sure what is wrong with the config.
paolo bevilacqua
Check "shpw isdn status", and "debug isdn q931" with "term mon".
I get this with show isdn status:
Global ISDN Switchtype = primary-ni
ISDN Serial0/0/0:23 interface
        dsl 0, interface ISDN Switchtype = primary-ni
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
        TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
    Layer 3 Status:
        0 Active Layer 3 Call(s)
    Active dsl 0 CCBs = 0
    The Free Channel Mask:  0x807FFFFF
    Number of L2 Discards = 0, L2 Session ID = 1
    Total Allocated ISDN CCBs = 0
Hi ryasuda26,
You mentioned external and internal (ip phone to ip phone?) calls arent working. Looking at the config, I see the 2901 is configured for MGCP and SRST. Let's break down the problem further:
1>     Need clarity on whether you can call IP phone to IP phone (Internal calls).
2>     Outputs needed from 2901: "show ccm-manager", "show mgcp endpoint"
3>     "debug isdn q931" from the 2901 for an outbound and inbound PSTN call.
4>     For the same test calls, collect detailed CUCM traces from all nodes in the cluster with the following trace settings applied to all nodes:
Cisco CallManager Trace Fields
Enable CDR Trace
Enable PRI Trace
Enable All Phone Device Trace
Enable ISDN Translation Trace
Enable MTP Trace
Enable All GateWay Trace
Enable Miscellaneous Trace
Enable Forward & Miscellaneous Trace
Enable MGCP Trace
Enable Music On Hold Trace
Enable Media Resource Manager Trace
Enable Annunciator Trace
Enable SoftKey Trace
Enable Route or Hunt List Trace
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080094e89.shtml#calm
5>     Call details like calling party number, called party number, timestamp of the test calls, IP address and MAC address of IP Phone, etc.
Once gathered, please upload here and I will take a look.
HTH.
Harmit.
