External Mask Spoofing/Randomizing
jnorthington
I have a group in the office that does collections and need their external mask to be changed frequently as the end customer will frequently block them.  Is there a way to randomize the outbound mask for SOME of my extensions but not necessarily all?
Dennis Mink
NO there is no such feature, assuming you use cisco call manager
Please remember to rate useful posts, by clicking on the stars below.
Ok.  I know someone somewhere is doing this.  What are they doing it with?
The only options I could think of would be that they're either using a TCL script they wrote, or they're using external call control profiles in CUCM to do this, either way, this involves some custom development.
java
if this helps, please rate
