External MIC For Cisco 8861 IP Phone
Ashish Bagla
Just need a little help with choosing an external MIC with Cisco 8861 IP Phone. The voice from Cisco inbuilt speaker is fine but the voice of the participant is not reaching well on the other side when he is little far away from IP Phone.
Please suggest a model and do let me know if somebody has been using the same too.
Thanks.
Ashish Bagla
Jonathan Schulenberg
Saying “MIC” in all caps is misleading as it implies an entirely different topic of Manufacurer Installed Certificate.
Take a look at the Jabra Speak 810.
https://www.jabra.com/business/speakerphones/jabra-speak-series
Ratheesh Kumar
Hi there
You could also try the new Cisco 500 series headsets (only wired at this time)
https://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/headset-500-series/datasheet-c78-740352.html
Platform Support
Cisco IP Phone 8861
RJ9
All phone loads posted on Cisco.com
Cisco IP Phone 8861
USB
12.1 (or later)
Hope this helps!
Cheers
Rath!
***Please rate helpful posts***
