Fallback Scenario
techguy
Level 4
Level 4
router#sh runn | sec fallback
call fallback active
call-manager-fallback
max-conferences 8 gain -6
transfer-system full-consult
ip source-address 10.1.209.1 port 2000
max-ephones 250
max-dn 500
dialplan-pattern 1 905........ extension-length 11
cor incoming user1 default
I am unable to dial when i am in fallback mode. Any clue???
5 Replies 5
techguy
Level 4
Level 4
During fallback, Router will use h323 outbound dial-peer or dialplan-pattern 1 905........ extension-length 11 given under call-manager-fallback section.
any clue???
Marwan ALshawi
can you post your CME config
As Marwan mentioned, you'll need to post your entire configuration to make sure you have dial-peers configured to match outbound calls going to the PSTN in SRST mode.
HTH,
Chris
dial-peer voice 1 pots
incoming called-number .
direct-inward-dial
dial-peer voice 10 pots
corlist outgoing call-international
tone ringback alert-no-PI
description International
destination-pattern 900.T
fax rate disable
port 0/0/0:15
prefix 00
dial-peer voice 11 pots
corlist outgoing call-nointernational
description Emergency
destination-pattern 9600....$
fax rate disable
port 0/0/0:15
prefix 600
dial-peer voice 12 pots
destination-pattern 9800.T
fax rate disable
port 0/0/0:15
prefix 800
dial-peer voice 13 pots
description Mobile
destination-pattern 905........$
fax rate disable
port 0/0/0:15
prefix 05
dial-peer voice 14 pots
description National
destination-pattern 90[234678].......$
fax rate disable
port 0/0/0:15
prefix 0
dial-peer voice 15 pots
description Local
destination-pattern 9[2345678]......$
fax rate disable
port 0/0/0:15
dial-peer voice 16 pots
destination-pattern 9[19]..$
fax rate disable
no digit-strip
port 0/0/0:15
forward-digits 3
dial-peer voice 101 voip
description To CallManager Pub
preference 1
destination-pattern 2999$
session target ipv4:10.50.2.3
voice-class codec 1
voice-class h323 1
dtmf-relay h245-alphanumeric
req-qos guaranteed-delay audio
acc-qos guaranteed-delay audio
fax-relay ecm disable
fax rate 14400
fax nsf 000000
fax protocol pass-through g711ulaw
no vad
dial-peer voice 201 voip
description To CallManager Sub
preference 2
session target ipv4:10.50.2.4
voice-class codec 1
voice-class h323 1
fax rate 14400
fax nsf 000000
no vad
dial-peer voice 301 voip
description CUE
huntstop
preference 3
b2bua
session protocol sipv2
session target ipv4:10.1.209.62
dtmf-relay sip-notify h245-alphanumeric cisco-rtp
codec g711ulaw
dial-peer voice 991 voip
preference 1
destination-pattern 991[67]$
voice-class codec 1
voice-class h323 1
fax rate 14400
fax nsf 000000
no vad
dial-peer voice 100 voip
preference 1
destination-pattern [789]..
voice-class codec 1
voice-class h323 1
fax rate 14400
fax nsf 000000
no vad
dial-peer voice 200 voip
huntstop
preference 2
destination-pattern 2[789]..$
voice-class codec 1
voice-class h323 1
fax rate 14400
fax nsf 000000
no vad
gatekeeper
