IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5780 Views
  • 14 replies
Hello,we have a customer who want to deploy the centralized call processing deplyment. The HQ contain the CUCMBE 8.0 and Voice gateway wich contain FXOs and E1 PRI lines.The Branch is connected with th HQ through WiMax and contains a voice gateway en...
Resolved! Call Waiting Alert
Hi guys,By default, CUCM plays a short beep tone to alert there is a second call entering and a visual alert. Some assistants are using Bluetooth headsets and are away from the phone, they can't see the visual alert. So the question here will be:Is t...
Resolved! Excel BAT for CME
Dear NetPro gurus,For Cisco CME 8.x, is it possible whether there are any scripts OR Excel spreadsheet that can be used to import into CME config rather than having to type in the CME commands line-by-line?Cheers
huntlee by Level 1
  • 1298 Views
  • 2 replies
Hican someone please explain how the config would look like for daisy chaining a Nortel phone and pc on a cisco switch!ip dhcp pool Nortel-Voice-105   network 172.16.105.0 255.255.255.0   default-router 172.16.105.1    option 128 ascii "Nortel-i2004-...
Hi I have the following issue with call forward feature.For the calls coming from the PSTN  an user configure the call forward feature to another IP phone into the same network and  it works fine but if the user try to configure the call forward  fea...
vulatec89 by Level 1
  • 405 Views
  • 2 replies
