Fax On Ramp for IOS 15.0 and above
Ben Morgan
Level 3
Level 3
Trying to configure the fax onramp app for IOS 15, I have successfully configured this app before on 12.x releases.. but cant seem to get it going on 15.x.
Im getting the "no route to destination" error on the isdn debug. I cant see where or how to debug the actual app so I can get visibility into what is actually going on. Seems like all the fax related debug commands are no longer.
Has anyone got this onramp to work in IOS 15 and above?
Config of what I have entered.
fax interface-type fax-mail
application
     service on-ramp flash:/app_faxmail_onramp.2.0.1.3.tcl
ip domain-name company.com
mta send server 192.168.1.50 port 25
mta send with-subject $s$
mta send mail-from username fax-service
mta send mail-from hostname company.com
dial-peer voice 9001 pots
description Match Fax Numbers
incoming called-number 5551234$
direct-inward-dial
service on-ramp
dial-peer voice 9002 mmoip
desc Outbound to Email
destination-pattern 5551234$
service fax_on_vfc_onramp_app out-bound
information-type fax
session target mailto:me@company.com
image resolution fine
mdn
dsn success
dsn failure
Your help is appreciated.
Ben
6 Replies 6
Jonathan Schulenberg
Did you reload after entering 'fax interface-type fax-mail'? This is a *mandatory* step.
Also, does a debug voip dialpeer confirm that 9001 was matched as the incoming POTS dial-peer?
Please remember to rate helpful responses and identify helpful or correct answers.
No I haven't reloaded the ISR yet, I will do.
Yes Dialpeer 9001 is matched, also if I remove/shutdown this dialpeer, I received the standard unnassigned/unallocated message. Which also leads me to believe the data is being stopped within the tcl script.
There was agreat doco on the Fax Onramp also including debugs. But like I mentioned in my initial post all the debug commands seemed to have been either purged off or now fall under a different subsection which I cant find.
http://www.cisco.com/en/US/tech/tk652/tk777/technologies_tech_note09186a00801fe5d9.shtml
Thanks for your response.
The debug commands and such will show up after you reload.
Cheers mate, makes sense, I will give the ISR a reload tonight.
Yes, debug commands did show, so thankyou for that.. however still unsuccessful
I debuged a few fax and mta related services
Output
Authentication:
     Method: IVR or unknown
     Status: SUCCESS
     Enabled: FALSE
     Template:
     List: fax
     MailtoAddress:
   Calling Oct3A=0x81
001362: Jul 11 10:05:45.785 AEST: //1268/7804BC3981B5/FOIP_ON/lapp_on_conference_vtsp_fmsp:
   Begin Conferencing VTSP and FMSP
001371: Jul 11 10:06:25.985 AEST: //1269/7804BC3981B5/FOIP_ON/lapp_on_call_disconnected:
   Cause Value=no user answer (19), Call Id=1269,
   Call Record(Call State=LAPP_ON_CS_FMSP_CALL_DETAIL(2),
   Disconnect Cause=,
   Call Id FMSP=1269, Call Id DMSP=0, Call Id MSPI=0, Call Id VTSP=1268)
001372: Jul 11 10:06:25.985 AEST: //1269/7804BC3981B5/FOIP_ON/lapp_on_call_disconnected:
   Disconnecting FMSP
001373: Jul 11 10:06:25.985 AEST: //1269/7804BC3981B5/FOIP_ON/lapp_on_call_disconnected:
   Call Record(Disconnect Cause=no user answer (19))
001374: Jul 11 10:06:25.985 AEST: //1268/7804BC3981B5/FOIP_ON/lapp_on_call_terminate:
   Cleanup Conferencing
001375: Jul 11 10:06:25.985 AEST: //1268/7804BC3981B5/FOIP_ON/lapp_on_conference_cleanup:
   Call Record(Conference Id VTSP FMSP=0x26C, Conference Done VTSP FMSP=FALSE;
   Conference Id FMSP DMSP=0x0,
   Conference Done FMSP DMSP=FALSE;
   Conference Id DMSP MSPI=0x0, Conference Done DMSP MSPI=FALSE)
001376: Jul 11 10:06:25.985 AEST: //1268/7804BC3981B5/FOIP_ON/lapp_on_conference_cleanup:
   Conference Id FMSP DMSP=0x0, Conference Done FMSP DMSP=FALSE;
001377: Jul 11 10:06:25.985 AEST: //1268/7804BC3981B5/FOIP_ON/lapp_on_conference_destroyed:
   Conference Id=0x26C,
001378: Jul 11 10:06:25.985 AEST: //1269/7804BC3981B5/FOIP_ON/lapp_on_disconnect_done:
   Call Id=1269,
Call Record(Call Id FMSP=1269, Call Disconnect Done FMSP=FALSE;
Call Id DMSP=0, Call Disconnect Done DMSP=FALSE;
   Call Id MSPI=0, Call Disconnect Done MSPI=FALSE;
   Call Id VTSP=1268, Call Disconnect Done VTSP=FALSE)
001379: Jul 11 10:06:25.985 AEST: //1269/7804BC3981B5/FOIP_ON/lapp_on_disconnect_done:
   Call Id=1269,
   Call Record(Call Id FMSP=1269, Call Disconnect Done FMSP=TRUE;
   Call Id DMSP=0, Call Disconnect Done DMSP=TRUE;
CC-VOICE-RTR01#
001380: Jul 11 10:06:25.989 AEST: %ISDN-6-DISCONNECT: Interface Serial0/1/0:28  disconnected from 288793850 , call lasted 40 seconds
001381: Jul 11 10:06:26.233 AEST: //1268/7804BC3981B5/FOIP_ON/lapp_on_disconnect_done:
   Call Id=1268,
001382: Jul 11 10:06:26.233 AEST: //1268/7804BC3981B5/FOIP_ON/lapp_on_disconnect_done:
   Call Id=1268,
   Call Id VTSP=1268, Call Disconnect Done VTSP=TRUE)
001383: Jul 11 10:06:26.233 AEST: //1268/7804BC3981B5/FOIP_ON/lapp_on_disconnect_done:
   All Calls Are Void Or Disconnected
001384: Jul 11 10:06:26.233 AEST: //1268/7804BC3981B5/FOIP_ON/lapp_on_call_terminate:
001385: Jul 11 10:06:26.233 AEST: //1268/7804BC3981B5/FOIP_ON/lapp_on_conference_cleanup:
   Call Record(Conference Id VTSP FMSP=0x26C, Conference Done VTSP FMSP=TRUE;
001386: Jul 11 10:06:26.233 AEST: //1268/7804BC3981B5/FOIP_ON/lapp_on_conference_cleanup:
CC-VOICE-RTR01#Call Record(Conference Id VTSP FMSP=0x26C, Conference Done VTSP FMSP=TRUE;
001387: Jul 11 10:06:26.233 AEST: //1268/7804BC3981B5/FOIP_ON/lapp_on_call_leg_cleanup:
   All Conferences Are Void Or Disconnected
001388: Jul 11 10:06:26.233 AEST: //1268/7804BC3981B5/FOIP_ON/lapp_on_call_terminate:
   Freeing the IVR Call Handoff Record
001389: Jul 11 10:06:26.233 AEST: //1268/7804BC3981B5/FOIP_ON/lapp_on_call_terminate:
   Freeing the Fax call record 001371: Jul 11 10:06:25.985 AEST: //1269/7804BC3981B5/FOIP_ON/lapp_on_call_disconnected:
   Disconnect Cause=,
   Disconnecting FMSP
   Call Id=1269,
   Call Id=1269,
CC-VOICE-RTR01#
   Call Id=1268,
   Call Id=1268,
Getting the no user answer code 19.. would this be talking about the application not picking tha fax up or the email address etc.
Just a continuation to the above..
Would the below config effect the T.37 fax negotiation?
The below is used for physical fax machines on this network.
voice service voip
address-hiding
supplementary-service h450.12
fax protocol pass-through g711alaw
h323
modem passthrough nse codec g711alaw maximum-sessions 20
