Fax Over IP Transfer
lpsnetwork
I tried to transfer an inbound fax to an outband fax as below :
Fax1 -------ITSP-------SIP-trunk--------CUBE--------CUCM -------- SIP-trunk---ITSP-------Fax2
Fax 2 is available when i dial him directly.
When i tried to send a fax from Fax1 to Fax2  there is a cancel in SIP messages
On Cube i just apply this command for T38 and inbound outband faxes works :
voice service voip
 address-hiding
 mode border-element license capacity 525
 allow-connections sip to sip
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 sip
  rel1xx disable
  session refresh
  header-passing
  error-passthru
  asserted-id pai
  privacy pstn
  early-offer forced
  midcall-signaling passthru
  privacy-policy passthru
Below some SIP messages ( in attach complete logs):
Received:
INVITE sip:+331708XXXXX@21.159.X.X:5060 SIP/2.0
Via: SIP/2.0/UDP 21.159.X.X:5060;branch=z9hG4bK0cBdd041bcd4da81538
To: <sip:+33170xXXXXX@21.159.X.X>
Call-ID: 755798237_121622568@21.159.X.X
CSeq: 2123 INVITE
Max-Forwards: 70
Allow: INVITE,ACK,CANCEL,BYE,REGISTER,REFER,INFO,SUBSCRIBE,NOTIFY,PRACK,UPDATE,OPTIONS
Accept: application/sdp, application/isup, application/dtmf, application/dtmf-relay,  multipart/mixed
Contact: <sip:+3375XXXXXX@21.159.X.X:5060>
Supported: timer,100rel
Session-Expires: 1800
Min-SE: 90
Content-Length:  310
Content-Disposition: session; handling=required
Content-Type: application/sdp
v=0
o=Sonus_UAC 21749 2003 IN IP4 21.159.X.X
s=SIP Media Capabilities
c=IN IP4 21.159.236.196
t=0 0
m=audio 16330 RTP/AVP 18 2 8 101
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:2 G726-32/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=sendrecv
a=ptime:20
Invite with divertion header
INVITE sip:+331408XXXXX@21.159.236.57 SIP/2.0
Via: SIP/2.0/UDP 21.159.X.X:5060;branch=z9hG4bK479731ED2
To: <sip:+331408XXXXXX@21.159.X.X>
Date: Thu, 23 Mar 2017 17:48:47 GMT
Call-ID: CCCE8F52-F2711E7-BE8DA4FF-C9587607@21.159.X.X
Supported: timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 4124897024-0000065536-0000086622-1862304021
User-Agent: Cisco-SIPGateway/IOS-15.5.3.S3
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1490291327
Contact: <sip:+33751808@21.159.X.X:5060>
Expires: 180
Allow-Events: kpml, telephone-event
Max-Forwards: 67
P-Asserted-Identity: <sip:+337XXXXXXX@21.159.X.X>
Diversion: "Test Fax"<sip:+331708XXXXX@21.159.X.X>;privacy=off;reason=unconditional;screen=yes
Content-Disposition: session;handling=required
Content-Length: 247
v=0
o=CiscoSystemsSIP-GW-UserA
4431-LON2-01F-CUBE-U1#gent 7173 7938 IN IP4 21.159.X.X
s=SIP Call
c=IN IP4 21.159.X.X
t=0 0
m=audio 16954 RTP/AVP 8 101
c=IN IP4 21.159.X.X
a=fmtp:101 0-15
a=ptime:20
Received:
SUBSCRIBE sip:+3314087XXXXX21.138.0.30:5060 SIP/2.0
Via: SIP/2.0/UDP 21.129.X.X:5060;branch=z9hG4bK72a1db7a9b91c7
From: <sip:+337XXXXXXXX@21.129.X.X>;tag=153710321~1f78a770-7fe4-81a3-46fb-0d284cb2492c-39200425
To: <sip:+3314087XXXX@21.138.X.X>;tag=7875C2AF-1457
Call-ID: f5dcef00-8d410a7f-5a4b12-6f008115@21.129.X.X
CSeq: 102 SUBSCRIBE
User-Agent: Cisco-CUCM10.5
Event: kpml
Expires: 7200
Contact: <sip:21.129.X.X:5060>
P-Asserted-Identity: <sip:+337XXXXXXXX@21.129.X.X>
Accept: application/kpml-response+xml
Max-Forwards: 70
Content-Type: application/kpml-request+xml
Content-Length: 370
<?xml version="1.0" encoding="UTF-8" ?>
<kpml-request xmlns="urn:ietf:params:xml:ns:kpml-request" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="urn:ietf:params:xml:ns:kpml-request kpml-request.xsd" version="1.0">
  <pattern interdigittimer="7260000" persist="persist">
    <regex tag="dtmf">[x*#ABCD]</regex>
  </pattern>
</kpml-request>
May i need to enable Fax Relay  or something else (passtrought)?
Thomas
Logically you should see a complete dialogue for the audio call getting connected and then a re-invite for the switch-over to fax protocol T38 where fax capabilities will be exchanged.
Abhay
Abhay Singh Reyal
The Only Way To Do Great Work Is To Love What You Do. If You Haven’t Found It Yet, Keep Looking. Don’t Settle
Thanks for your answers,
As we configured divert option, in the diversion header there is the DDI belong to us , so the call is authorized.
Abhay, it's true the call is not establish , before modify config of T38 , i have to check why the call is not establish.
In this kind of calls , MTP is maybe required ? that's maybe why i received a cancel
We don't enable MTP required as we are in full G711 on trunk beetween CUBE and CUCM
Thomas
Chris Deren
Is your ITSP carrier allowing you to send calls with caller ID not belonging to you? It is often times not allowed and one needs to insert owned caller ID in diversion header.
To test it can you make a similar call from external phone that is forwarded to another external destination?
