fax problem
abukuru95
Level 3
Level 3
Hello Friends, i am actually  experiencing a fax problem since my client changed to another service  provider. when a fax is sent, it is sometimes successful but at times  only partial pages are received or blank pages.the service provider  changed the fax box, did some tests and confirmed that there wasnt any  problem by their side.i tried checking out configuration, all seems  fine.nothing has changed.
what could be the possible cause ? how  can i troubleshoot this ? your help would be appreciated.My client is  using a cisco unified call manager express 2811 with an fxs port  installed on it.
what is the most appropriate configuration for such an incident.
best regards.
yuanwu
Hi, Abukura95
Did you go through the following excellent fax project done by Abu Hadee?  Please check if those information will help you  out.
https://supportforums.cisco.com/community/netpro/collaboration-voice-video/ip-telephony/blog/2010/10/26/fax-configuration-and-troubleshooting-project
Rgds/Randy
thanks Randy, will try it  out
