Phone firmware
Hi all
Cisco recommends to install new firmware on all servers in the cluster. If I have a 3 server cluster with 2 tftp servers, why do I have to install the firmware on all 3 servers and not only on the 2 tftp servers?
What exactly does the firmware installation besides installing the necessary files on the tftp server and updating the default phone load?
Thanks!
kusatija
Hi Thijs,
Are all the servers on one site, is it a centeralized or distributed implementation?
Cisco recommends you to upload the firmware on all the nodes as you can enable tftp services on all the nodes at any point, so all the files are there if you activate the tftp server on a node for any reason.
Technically you do not need to upload the firmware on all the nodes and just the node where the tftp services are running.
Here is one scenario I have experienced in a scenario. Customer had only
one TFTP server, the cluster is spread over two data center centers.
During the night of upgrade, they turned on TFTP service on one sub.
Since the Cop files were on all the servers including this sub, so they
could use two tftp(one is temp one) for the upgrade.
Hope that makes sense!
Kunal
kusatija
Hi Thijs,
Kunal
Yes Kunal, that makes sense
Thanks for your help!
Thijs
