Faxing issue with XMedius
David Perez
Hi NetPro,
I am here to ask for some assistance in this issue that I have been trying to resolve for the past few months.
Here is a summary of the issue we are having. When we send faxes, the receiving end will receive only the 1st page, or they will receive the fax over and over again. We believe this is happening because our system is not receiving an acknowledgement from the far end. ( this might be a configuration issue or issue in the pstn, though are ISP thinks over wise)
We are using XMedius faxing to send faxes through Call Manager, to the gateway, out of our PRI.
Details : XMedius to CUCM via SIP trunk. CUCM to Gateway via MGCP.
CUCM 8.6
IOS : c2900-universalk9-mz.SPA.152-3.T2.bin
XMedius : 6.5
I would really really appreciate some assistance. We’ve had many calls with cisco, xmedius, and our isp, but there is still no resolution.
Xmedius has viewed the wireshark captures and shows us that the software is not receiving confirmation from the far end. The system is designed to retry 3 times if the faxes fail due to errors.
Below is the output of show mgcp :
MGCP Admin State ACTIVE, Oper State ACTIVE - Cause Code NONE
MGCP call-agent: CUCM SERVER 2427 Initial protocol service is MGCP 0.1
MGCP validate call-agent source-ipaddr DISABLED
MGCP validate domain name DISABLED
MGCP block-newcalls DISABLED
MGCP send SGCP RSIP: forced/restart/graceful/disconnected DISABLED
MGCP quarantine mode discard/step
MGCP quarantine of persistent events is ENABLED
MGCP dtmf-relay for VoIP is SDP controlled
MGCP dtmf-relay for voAAL2 is SDP controlled
MGCP voip modem passthrough disabled
MGCP voaal2 modem passthrough disabled
MGCP voip modem relay: Disabled
MGCP T.38 Named Signalling Event (NSE) response timer: 200
MGCP Network (IP/AAL2) Continuity Test timer: 200
MGCP 'RTP stream loss' timer disabled
MGCP request timeout 500
MGCP maximum exponential request timeout 4000
MGCP rtp unreachable timeout 1000 action notify
MGCP gateway port: 2427, MGCP maximum waiting delay 3000
MGCP restart delay 0, MGCP vad DISABLED
MGCP rtrcac DISABLED
MGCP system resource check DISABLED
MGCP xpc-codec: DISABLED, MGCP persistent hookflash: DISABLED
MGCP persistent offhook: ENABLED, MGCP persistent onhook: DISABLED
MGCP piggyback msg ENABLED, MGCP endpoint offset DISABLED
MGCP simple-sdp ENABLED
MGCP undotted-notation DISABLED
MGCP codec type g711ulaw, MGCP packetization period 20
MGCP JB threshold lwm 30, MGCP JB threshold hwm 150
MGCP LAT threshold lwm 150, MGCP LAT threshold hwm 300
MGCP PL threshold lwm 1000, MGCP PL threshold hwm 10000
MGCP CL threshold lwm 1000, MGCP CL threshold hwm 10000
MGCP playout mode is adaptive 60, 40, 1000 in msec
MGCP Fax Playout Buffer is 300 in msec
MGCP media (RTP) dscp: ef, MGCP signaling dscp: af31
MGCP default package: fxr-package
MGCP supported packages: gm-package dtmf-package trunk-package line-package
                         hs-package rtp-package atm-package ms-package dt-package
                         mo-package mt-package sst-package fxr-package pre-package
                         md-package
MGCP Digit Map matching order: shortest match
SGCP Digit Map matching order: always left-to-right
MGCP VoAAL2 ignore-lco-codec DISABLED
MGCP T.38 Max Fax Rate is DEFAULT
MGCP T.38 Fax is ENABLED
MGCP T.38 Fax ECM is DISABLED
MGCP T.38 Fax NSF Override is DISABLED
MGCP T.38 Fax Low Speed Redundancy: 1
MGCP T.38 Fax High Speed Redundancy: 1
MGCP Fax relay SG3-to-G3: ENABLED
MGCP Fax relay ANSam suppression: DISABLED
MGCP control bound to interface Loopback0
MGCP media bound to interface Loopback0
MGCP Upspeed payload type for G711ulaw: 0, G711alaw: 8
MGCP Dynamic payload type for Cisco fax indication: 96, Cisco fax ack: 97
MGCP Dynamic payload type for G.726-16K codec
MGCP Dynamic payload type for G.726-24K codec
MGCP Dynamic payload type for G.726-32K codec
MGCP Dynamic payload type for G.Clear codec
MGCP Dynamic payload type for NSE is 100
MGCP Dynamic payload type for NTE is 99
MGCP rsip-range is enabled for TGCP only.
MGCP Comedia role is NONE
MGCP Comedia check media source is DISABLED
MGCP Comedia SDP force is DISABLED
MGCP g729 variants use static payload type and contain annexb in SDP
MGCP Guaranteed scheduler time is DISABLED
MGCP Disconnect delay error recovery DISABLED
MGCP DNS stale threshold is 30 seconds
Thank you very much in advance, any recommendations would be highly appreciated
David
6 Replies 6
Jorge Armijo
Level 4
Level 4
So the call flow looks something like this:
Telco---PRI---GW---MGCP---CUCM---SIP---XMedius?
Now:
"Xmedius has viewed the wireshark captures and shows us that the software  is not receiving confirmation from the far end. The system is designed  to retry 3 times if the faxes fail due to errors."
What is the confirmation message missing? Can they elaborate on this?
What Fax Protocol is being used by XMedius? If I had to guess, I'll say t.38?!?!
Please post the full "show run" and "show version" from the MGCP GW, as well the configuration of the SIP Trunk that poitns to XMedius.
Thx
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
Yes this is the correct flow : Telco---PRI---GW---MGCP---CUCM---SIP---XMedius
Yes to the t.38 being used.
The sip trunk is configured in cucm.
Unfortunately I am not very familiar with faxing so I am not sure what they meant.
They explained it to me by showing me the wire shark voip call flow.
I believe they said that once we send the 1st page, we do not get a confirmation from the receiving end that they got it.
That is why xmedius continues to fax the 1st page over and over again.
Here is a show run of that gateway :
version 15.2
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
no service password-recovery
hostname voicegw01
boot-start-marker
boot system flash:c2900-universalk9-mz.SPA.152-3.T2.bin
boot-end-marker
card type t1 0 0
card type t1 0 2
logging buffered 1000000
aaa new-model
aaa authentication login default group tacacs+ local
aaa authorization exec default group tacacs+ local
aaa authorization network default group tacacs+ local
aaa accounting send stop-record authentication failure
aaa accounting exec default
action-type start-stop
group tacacs+
aaa accounting commands 1 default
action-type stop-only
group tacacs+
aaa accounting commands 15 default
group tacacs+
aaa accounting network default
aaa accounting connection default
group tacacs+
aaa accounting system default
group tacacs+
aaa session-id common
clock timezone PST -8 0
clock summer-time PDT recurring
network-clock-participate wic 0
network-clock-participate wic 2
network-clock-select 3 T1 0/2/0
no ipv6 cef
no ip source-route
ip domain name XXXXXXX.org
ip name-server XXX.XXX.XXX.XXX
ip cef
isdn switch-type primary-ni
trunk group ANALOG
voice-card 0
voice-service dsp-reservation 50
dsp services dspfarm
voice service voip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw
voice iec syslog
license udi pid CISCO2921/K9 sn FTXXXXXXXXXXX
hw-module pvdm 0/0
hw-module pvdm 0/1
archive
log config
logging enable
logging size 200
notify syslog contenttype plaintext
hidekeys
path ftp://XXXXXXXXXXXXXXXXXXXX
write-memory
username XXXXXXXXXX privilege 15 secret 5
redundancy
controller T1 0/0/0
clock source internal
cablelength long 0db
pri-group timeslots 1-24 service mgcp
controller T1 0/0/1
cablelength short 110
description
controller T1 0/2/0
pri-group timeslots 1-4,24 service mgcp
description
controller T1 0/2/1
ip ssh version 2
interface Loopback0
ip address XXX.XXX.XXX.XXX 255.255.255.255
no ip proxy-arp
ip ospf 100 area 131
interface Loopback1
shutdown
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description
ip address XXX.XXX.XXX.XXX 255.255.255.252
no ip proxy-arp
ip ospf message-digest-key 10 md5 7
ip ospf dead-interval 3
ip ospf hello-interval 1
duplex auto
speed auto
interface GigabitEthernet0/1
description
no ip proxy-arp
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:23
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
interface Serial0/0/1:23
no ip address
encapsulation hdlc
no cdp enable
interface Serial0/2/0:23
no ip address
encapsulation hdlc
no cdp enable
router ospf 100
router-id XXX.XXX.XXX.XXX
auto-cost reference-bandwidth 100000
area 131 authentication message-digest
area 131 stub no-summary
timers throttle spf 50 200 3000
timers throttle lsa 50 200 3000
timers lsa arrival 100
passive-interface Loopback0
ip forward-protocol nd
no ip http server
no ip http secure-server
ip tacacs source-interface Loopback0
ip access-list standard
permit XXX.XXX.XXX.XXX
deny   any log
ip access-list standard SSHin
permit XXX.XXX.XXX.XXX 0.127.255.255
deny   any log
permit XXX.XXX.XXX.XXX 0.0.1.255
permit XXX.XXX.XXX.XXX 0.0.0.255
deny   any log
logging source-interface Loopback0
logging XXX.XXX.XXX.XXX
snmp-server group snmpmonitor v1 access snmpmonitoring
snmp-server community XXX
snmp-server enable traps entity-sensor threshold
tacacs-server host XXX.XXX.XXX.XXX
control-plane
voice-port 0/0/0:23
voice-port 0/2/0:23
voice-port 0/1/0
trunk-group ANALOG
description ANALOG Backup 999-999-9999
voice-port 0/1/1
trunk-group ANALOG
voice-port 0/1/2
shutdown
description ANALOG Not Used
voice-port 0/1/3
shutdown
voice-port 0/0/1:23
ccm-manager fallback-mgcp
ccm-manager redundant-host Publisher
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server Subscriber Publisher
ccm-manager config
mgcp
mgcp call-agent Subscriber 2427 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
mgcp default-package fxr-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 ls_redundancy 1
mgcp fax t38 hs_redundancy 1
mgcp bind control source-interface Loopback0
mgcp bind media source-interface Loopback0
mgcp profile default
sccp local Loopback0
sccp ccm xxx.xxx.xxx.xxx identifier 1 priority 1 version 7.0
sccp ccm xxx.xxx.xxx.xxx identifier 2 priority 2 version 7.0
sccp
sccp ccm group 1
bind interface Loopback0
associate ccm 1 priority 1
associate ccm 2 priority 2
associate profile 1 register XCODE
associate profile 2 register CFB
associate profile 3 register VCB
dspfarm profile 1 transcode
codec g722-64
codec g711ulaw
codec g729ar8
maximum sessions 5
associate application SCCP
dspfarm profile 2 conference
codec g722-64
codec g711ulaw
codec g729ar8
maximum sessions 3
dspfarm profile 3 conference video homogeneous
codec g729ar8
codec g711ulaw
codec g722-64
codec h264 vga frame-rate 30 bitrate 1mbps
maximum sessions 4
gatekeeper
shutdown
banner login ^CC
WARNING
Authorized Access Only
^C
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
session-timeout 30
access-class SSHin in
exec-timeout 15 0
logging synchronous
transport preferred ssh
transport input ssh
scheduler allocate 20000 1000
ntp server xxx.xxx.xxx.xxx prefer
end
voicegw01#
Here is a show version for the gateway :
show ver
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.2(3)T2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Wed 26-Sep-12 07:24 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M1, RELEASE SOFTWARE (fc1)
voicegw01 uptime is 8 weeks, 6 days, 20 hours, 13 minutes
System returned to ROM by reload at 20:10:55 PDT Thu Jul 25 2013
System restarted at 20:12:13 PDT Thu Jul 25 2013
System image file is "flash:c2900-universalk9-mz.SPA.152-3.T2.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2921/K9 (revision 1.0) with 479232K/45056K bytes of memory.
Processor board ID FTXXXXXXXXX
3 Gigabit Ethernet interfaces
53 Serial interfaces
1 terminal line
4 Channelized T1/PRI ports
4 Voice FXO interfaces
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
254464K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#            PID                             SN
*0         CISCO2921/K9         FTXXXXXXXX
Technology Package License Information for Module:'c2900'
Technology   Technology-package           Technology-package
             Current       Type           Next reboot
ipbase       ipbasek9     Permanent     ipbasek9
security     None         None           None
uc           uck9         Permanent     uck9
data         None         None           None
voicegw01#
Thank you very much Jorge!
Make sure you have the following commands:
no mgcp fax t38 inhibit
mgcp package-capability fxr-package
no mgcp fax t38 ecm
mgcp fax t38 nsf 000000
Just for testing, set to default value "0":
mgcp fax t38 ls_redundancy 1 <-- 0
mgcp fax t38 hs_redundancy 1 <-- 0
Re-register the Gateway with CallManager by entering the following commands :
no mgcp
mgcp
Jorge Armijo
These commands are there:
no mgcp fax t38 ecm
I will try to add :
Here is a question i do have :
Would changing the max fax rate from default to 14400 make a difference?
this was something xmedius recommend doing to hardcode it
to
MGCP T.38 Max Fax Rate is 14400
Thank you again Jorge
In addition to what Jorge suggested:
  • Ensure that the CUCM MGCP gateway has T.38 Fax Relay enabled and Cisco Fax Relay disabled. If you type the commands on the router but not CUCM they will likely be overriden from CUCM the next time you click Save.
  • For MGCP to SIP T.38 interworking you also need the gateway to have the following commands. Without them, CUCM will likely invoke an MTP, which will break T.38.
      • mgcp package-capability fm-package
      • mgcp dtmf-relay voip codec all mode nte-ca
      • In CUCM config, set Type of DTMF Relay to NTE-CA (*not* Current Config or NTE-GW) so they match.
    • Personally, I don't agree with disabling ECM as it's likely a symptom and not a cause but it won't hurt to test with it off.
    As for the DEFAULT vs. 14400 setting: essentially it means that the transmission rate cannot exceed the bandwidth of what the equivelent audio call would be. If it's G.711 then 14400 will be fine. If you're normally forcing audio calls down to G.729 then faxes would be capped at 7200. You would see that happening in the XMediusFAX console though.
    Did you end up resolving this issue? Your issue description is largely similar to mine.
