I need clarification on the actual extensions required for each certificate. I no longer trust the Cisco documentation.The OS guide for cucm and im&p states: • The CAPF CSR uses the following extensions:X509v3 extensions: X509v3 Key Usage: • Digi...
Collaboration Community, I am looking to setup a couple conference room phones but would like to not utilize more than one DN if possible, is it recommended or considered best practice to use a shared DN between conference phones or utilize one DN...
HiI have 2 parallel 3925E (IOS 15.6) systems configured for call routing between 2 parallel gateways and internal PBX'sI need to do maintenance on one of the systems so I want to stop the establishment of new calls whilst maintaining existing calls u...
I need help setting up a phone i purchased.
Hi,When I do a “SHOW SIP-UA REGISTER STATUS”, I got two records: one is showing ".*" which registered status shows no; another one is the actual SIP number which registered status shows yes. Please see attached screenshot. I got a problem of incoming...
We are CUCM 12.5 and using CiscoJVDI-12.0.0 in Citrix Desktop.If we create a multi-line Jabber the second line shows up outside of the the Citrix Environment but in Citrix you do not see the dropdown on Jabber for the second line. When a call is rece...
Cisco Hi All,If I can please pick your brain regarding the SIP / VOIP issue that happened after we migrated over to our new Provider.Device Setup: Cisco IP Phones > Cisco POE Switch > Cisco 2811 PABX > MIkrotik CCR1036 > ISPWhen I did the Sip Trunk t...
Hi,We have a cluster where certain phones should make outbound PSTN calls with their calling ID withheld. It's currently done at the router pattern level, meaning for these phones we need a separate set of PSTN route patterns, partitions and callin...
Hi!Is it possible to change background image on IP phone 7962 in CUMCE ver. 4.1. I'm trying according different guides which are published on this forum and without results. Maybe it's a CUMCE 4.1 version problem (too old).
Hi Everyone, I am getting the below error from InformaCast. InformaCast version is 12.5.1 24817 and Call Manager version is 11.5.1.10000-6. Unable to build recipient groups: java.lang.Exception: The Cisco Unified Communications Managers given for clu...
I have 2 clusters A and B connected over a SIP trunk, extension to extension calls between them are completely fine. But when a phone on either side is forwarded to PSTN, then calls don't complete. If a phone on cluster B is forwarded to PSTN and get...
I'm running into problems getting Click to Call to work in Office 2003 applications. Click to Call seems to be functioning properly in Internet Explorer but not Word and Excel. Right-clicking on a number doesn't generate the "Call" or "Call with edit...
Hi, my cisco ip phone CP-3905 in the Unprovisioned mode , althought i'm checked the firmware is newest version (CP3905.9-4-1SR2-2) ! How can i fix it ?cli.log : 00:00:21:214 x [CENTRAL] State transit CONFIGURING_IP --> PROVISIONING 00:00:21:231 x [...
Hi I installed CUAS 11.0.4 on windows 10 and doesn´t work fine. I logged properly but when I try to create Directory Group i received a message Failed to save directory group information. Other issue is I can´t park calls, it shows me there are no pa...
Subject | Author | Posted |
01-16-2025 02:00 AM | ||
01-14-2025 10:33 PM | ||
01-08-2025 01:34 AM | ||
01-05-2025 12:44 AM | ||
01-03-2025 09:47 AM |
User | Count |
4 | |
2 | |
2 | |
1 | |
1 |
