09-08-2020 07:08 AM
I have two questions.
Can I filter only those phones that are marked as unregistered? I want to see only unregistered phones in the phone list.
And I want to know the time when the phone changed to unregistered.
Is there a way??
Solved! Go to Solution.
09-08-2020 02:57 PM
You could use RTMT to do a Device Search for phones in unregistered status, but that list is view only and not exportable. There may be a way to do a SQL search via the command line, but I don't know how to do that myself.
Maren
09-24-2020 02:03 AM
Data Export)
Data is captured after tracking status in RTMT.
Afterwards, extracting the text from the screenshot is simple.
09-08-2020 07:21 AM
It depends on your version of CM. With 12.5 and likely also 12.1 you have information about registration status. In that webUI you can search by Last Registered and Last Active.
09-08-2020 08:32 AM
CUCM is version 8.6.2
09-08-2020 12:03 PM
Then unfortunately no.
09-08-2020 02:57 PM
Maren
09-09-2020 01:38 AM
Can you provide a guide for each staff??
RTMT is installed.
09-09-2020 07:19 AM
Nope, no way via SQL (at least not on his version), that info was not stored anywhere until 12.5 where you see the last active and last registered status.
09-24-2020 02:03 AM
Data Export)
