Firmware Compatibility
Leonardo Santana
I have an doubt we have an CUCM 8.6 with 7911 and 7941 using the following firmwares:
7911 SCCP11.9-3-1-1S
7941SCCP41.9-2-1SR2S
We will put an CME 7.0.1 that was running before the CUCM 8.6 my question is, i see that CME supports this firmwares versions:
7911 SCCP11.8-3-3S.loads*
7941 SCCP41.8-3-3S.loads
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/cme701spc.htm
Do i need to downgrade my IP Phones to version 8.3.3 if i keep versions 9-3 and 9-2 they will work?
Leonardo Santana
Leonardo Santana
*** Rate All Helpful Responses***
2 Accepted Solutions
Rob Huffman
Hi Leonardo,
We don't run CME except in the lab so I'm not an expert here
We do know that device firmware versions are not dependant or
related to the specific CME/IOS that you are running so you should be good to go.
You could always try to upgrade the CME with the matching firmware just in case
you add new phones and want them to have the same loads.
Cheers!
Rob
"May your heart always be joyful
May your song always be sung" - Bob Dylan
Chris Deren
No, newer firware will work just fine.
Chris
Rob Huffman
Hi Leonardo,
Cheers!
Rob
Chris Deren
Chris
Once again thanks Rob and Chris!
i will test and share the results!
Leonardo Santana
Leonardo Santana
