Firmware Upgrade issue - 7962G from SCCP42.9-3-1-SR1-1S to SIP
Suvenduji
Dear Experts!!
This is my first query on this forum.
I am trying to upgrade a brand new Cisco 7962G from SCCP42.9-3-1-SR1-1S to SIP 8.5.3 or 8.5.4.
I am not using UCM and instead using TFTP server.
In the past (approx. 12 months back)  I was able to upgrade the 7962G phones to SIP 8.5.3 but the new phones complain with an error "Load rejected HC". I tried to upgrade it to a higher version 9-3-1SR3-1 but the proxy ports are showing null values and not able to register with my SIP registrar (3rd party non-Cisco).
Is there any change on the new 7962G compared to the previous ones available a year back?
Any advice would be great help.
Many thanks in advance.
Suvendu
2 Accepted Solutions
Gordon Ross
Level 9
Level 9
Yes, there has been a hardware change on some devices which forces the use of later versions of firmware.
See this Cisco document:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/7900_series/firmware/9_3_1SR1/release_notes/P790_BK_R4E1E768_00_rn-9_3_1_sr1-7900-series/P790_BK_R4E1E768_00_rn-9_3_1_sr1-7900-series_chapter_00.pdf
GTG
Please rate all helpful posts.
Check if your current hardware falls under this category
Phone
Hardware Version
Cisco Unified IP Phone 7942G
15.0 and higher
Cisco Unified IP Phone 7962G
15.0 and higher
Cisco Unified IP Phone 7945G
13.0 and higher
Cisco Unified IP Phone 7965G
13.0 and higher
Cisco Unified IP Phone 7975G
12.0 and higher
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/7900_series/firmware/9_3_1SR1/release_notes/P790_BK_R4E1E768_00_rn-9_3_1_sr1-7900-series/P790_BK_R4E1E768_00_rn-9_3_1_sr1-7900-series_chapter_00.html
Nishant Savalia
Regards, Nishant Savalia
5 Replies 5
Gordon Ross
Level 9
Level 9
GTG
Phone
Hardware Version
15.0 and higher
15.0 and higher
13.0 and higher
13.0 and higher
12.0 and higher
Nishant Savalia
Hi Nishant/Gordon,
Thanks for your responses. I managed to upgrade the firmware from SCCP to SIP.
However, Proxy Port on my phone is empty and possibly as a result of this it's not sending any SIP registration messages. Register with Proxy flag is set to True and SIP Line is configured with extension and proxy IP.
Please see the phone information I retrieved from the phone post upgrade.
Am I missing something here?
Phone DN7492
App Load IDjar42sip.9-3-1ES26.sbn
Boot Load IDtnp62.9-3-1-57.bin
Version*SIP42.9-3-1SR4-1S*
Expansion Module 1
Expansion Module 2
Hardware Revision16.0
Serial NumberFCH173084JX
Model NumberCP-7962G
Message WaitingNo
UDIphone
Cisco Unified IP Phone 7962G, Global
CP-7962G
V15
FCH173084JX
Time5:40:22a
Time ZoneGreenwich Standard Time
Date26-01-14
System Free Memory6705824
Java Heap Free Memory1128836
Java Pool Free Memory245024
FIPS Mode EnabledNo
Suvendu
Please note, I am not using Cisco UCM. I am trying to register the phone with a 3rd party SIP Server.
Upgraded SIP firmware version is - SIP42.9-3-1SR4-1S
Thought of adding these points which might be helpful to make any suggestion.
Dear Gordon,
As per my previous post, I managed to upgrade the firmware to 9.3.1 (SIP42.9-3-1SR4-1S) based on your/Nishant's input.
However, my phone is not generating any SIP registration messages. Line1 and Line2 are configured with correct SIP server IP details however SIP proxy port is empty. Register with proxy flag is set to true. I am trying to register with a 3rd party SIP proxy.
Seems new 7962G won't allow you to change the SIP proxy port via Phone Settings.
I am using below SEPxxxx.cnf.xml file configure the phone line. Anything wrong here?
Please advise. We are stuck with lots of new phones where as all OLD phones are working fine.
  true
  SIP
  user
  pass
      D-M-YA
      BST
          NTP SERVER IP
          Unicast
              2000
              5060
              5061
            IP ADDRESS OF 3rd party SIP SERVER
      5060
      true
      true
      x-cisco-serviceuri-cfwdall
      x-cisco-serviceuri-pickup
      x-cisco-serviceuri-opickup
      x-cisco-serviceuri-gpickup
      x-cisco-serviceuri-meetme
      x-cisco-serviceuri-abbrdial
      false
      true
      true
      true
      6
      60
      120
      4000
      70
      false
      None
    false
    true
    false
    true
    g729a
    101
    avt
    false
    false
    false
    15000
    false
    16384
    32766
        9
        7492
        5060
        7492
        7492
        false
          true
          false
          true
          true
    5060
    184
    DRdialplan.xml
    SK50719900-3bee-4594-bc3f-6400e1a33bf0.xml
    cisco
    true
  SIP42.9-3-1SR4-1S
    false
    false
    08:00
    10:30
    01:00
  1136932173-57191cee-5ffc-4342-b286-4246b4991890
    English_United_States
    en_US
    1.0.0.0-1
    iso-8859-1
  United_States
    United_States
    64
    1.0.0.0-1
  false
