Hi ; I am getting one issue i.e Callmanager (8.6.2) with centralized call process having multiple CUE (ver 7 & 8.6 ) registered for Auto Atendent msg for multiple branches ,after one week or couple of days all CTI Rpoint and ports are unregister...
Hello, When we pickup a call using agent desktop, the agent screen pops up in front of any opened window on the screen. We are looking to change this behaviour so when call is picked using the agent, the agent doesn't pops up and cover the app that t...
Hi All,I think I know the answer to this question but wanted to put it out here in case anyone has an alternate solution. My client wants to the following behavior on the phones: User has a Cisco 7945 phone with a single DID which is set to Max Calls...
Is it possible to configure a phone to default back to the main line (LINE 1) after completing a call?We just implemented this system and out current setup we have is an Intercom line (Line 2 - No Outside calls) and their normal line (Line 1 - Outsid...
I was wondering if anyone had a CUBE SIP Profile example for rewriting SDP to fix private-to-public IP address in the SDP so that CUBE can be used behind a static NAT without SIP ALG.
trying to setup voicemail on our new CCME system but every time i call voicemail i get a busy signal. i pretty sure i have the setup correct for dialing into the the voicemail. when i do a "sh license status application" in the CUE command line i get...
Hi Support CommunityWe are using CUCM 8.6.2 and we have 3000 user device profiles. Issue is we only have 2500 staff so clearly some house keeping needs to be done. You can run a report that shows you logged in extension mobility users and date/time t...
Dear Team,We need your technical assistance for one the task which looks some critical and challenging. Hope I get the most appropriate and best technical suggestion from Cisco Experts. Here are details for the task: Current Call Manager VersionVers...
Hello, All. I've come upon an issue with the 7965 Model Phones and the "Display On If Incomign Call" option. By default, CUCM has that option disabled. In order to combat this, I have modified a Common Phone Profile deployed to all phones. This has p...
Hi all,I have two CUCM 9.1 connected correctly and synchronized to ldap server, when i try to login with an ldap user, I got two result:* with Publisher address I can access to my user web page* with subscriber address I can't access to my user web p...
Hifor security reason i need to have a 'normal' fxo phone in parallel of a fxo port on a 2911.the idea is to be able to see incoming call even in case of 2911 failure.the 2911 is working as stand alone and not managed by call manager.it receive fxo c...
Unity Connection 8.5 and 8.6.2 SU1 get Java Security Exception "Missing required permissions manifest" any time I try to play a sound file.This occurs on IE 10 and Firefox 27.0.
Hello , i have unity connection 9x (Business Edition ) , i want to delelet all voice messages (for all users ) from their mailboxes . is there any way ? please advice .
Hello , i have configured , cisco jabber on iPhone. i am facing one way sudio issue . issue description is as below : if i call from JABBER-iphone to Desk phone i can not hear the voice from DESK phone but Desk phone user can not hear me ? i have cu...
Hi Everybody, Now i am using VG2901 version 15.2(2)TWe are using E1 curcuit to connect the PSTN show isdn status Layer 1 is active Layer 2 is MULTIPLE_FRAME_ESTABLISHED When I tried to dial the local number 28881000, it seems cannot establish the ca...
| Subject | Author | Posted |
| 01-16-2026 03:24 AM | ||
| 12-31-2025 01:52 PM | ||
| 12-10-2025 11:24 AM | ||
| 11-16-2025 10:18 PM | ||
| 10-15-2025 09:15 AM |
