flex license
susim
Level 3
Level 3
I have cucm pub and sub ,unity pub and sub , and cup ,one expressway c and e
To upgrade 11.5 from to the latest , do I need all the licenses below ?
If I remove the unity and cup is there any differences in the licensing ?
7 Replies 7
You are not paying for all the line items. may items are free and 0 $.
The Phone license are  P-EA,P-ACC,P-CA
P-UCXN is for unity
Even if you remove the IM and Unity i don't see any difference because  I assume the p-UCXn is 0$ since its a part of EA.
Response Signature
Hi @Nithin Eluvathingal
Thanks for the reply .
A-FLEX-EAPL what about EAPL License
EAPl is the option you selected to choose the number of EA user license. On your BOQ I assume that’s  the only line item which has cost.
based on the number you selected on EAPL you will see
P-EA,P-ACC,P-CA & P-UCXN
with EA you get 20% EA license,20% Access licenses and 50% common area license free.
Response Signature
is  A-FLEX-NUPL-P ,E ,A  and A-FLEX-EAPL are same ?
vijayparthi1
Anyone can answer whether Cisco partners are eligible to sell ( resale to customer ) flex licenses or only be entitled to the customer only?
AFAICT your question is off-topic to the OP. Recommend you to create your own post to ask your question.
Response Signature
