Forcing Phone to download Firmware Files
GRANT3779
Hi All,
If I have a phone which is using old firmware files, lets just say a 7942. Is it just a case of downloading the new ones from Cisco, uploading them to my CME, stick in my tftp-server commands so the CME router can serve them, and add the load command for that model of phone? WIll the phone automatically pull down the new files then after I reboot it, or do I need to do anything else?
Manish Gogna
That should be good enough, all steps are explained in the link below.
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_configuration_example09186a00805a2fa5.shtml
Manish
