09-19-2012 09:15 AM - edited 03-16-2019 01:17 PM
Hi voice team,
I have the follow environment below:
PSTN CALLS -------->>> Voice gw Cisco >>> CUCM >>> Cisco IP phones
|| (Via ISDN)
Analog central
For example: I have a Ip phone with "Forward all" for a analog phone.
So, I have two cases below:
- Working case: When the calling number is a ip phone (internal phone). (It´s fine)
- Issue case: When the calling number is a PSTN number.
Can you help me please ?
thanks.
Solved! Go to Solution.
09-19-2012 09:32 AM
Your Forward All CSS have the priveligies to call PSTN Numbers?
Leonardo Santana
09-19-2012 09:32 AM
Leonardo Santana
09-19-2012 09:40 AM
Sorry, the answer is not correct.
The first condition that I put in the post strip this possibility.
thanks.
