Enabling inbound caller id?
jbaril_ceb
We're using CUCM version 5.1.3.8000-4 and a Cisco 2881 as VoIP-Router.
I'm doing tests on FXO port 0/1/3 where caller ID service is active from phone service provider.
On 2881, show call active voice brief command giving me right inbound caller ID information.
330F : 8832 1349297480ms.1 +-10 pid:0 Originate  connecting
dur 00:01:24 tx:2801/448160 rx:1613/257603
IP 192.168.200.22:28770 SRTP: off rtt:0ms pl:18910/0ms lost:0/1/0 delay:60/60/65ms g711ulaw
media inactive detected:n media contrl rcvd:n/a timestamp:n/a
3312 : 8833 1349308960ms.1 +0 pid:8 Answer 4501231234 active
dur 00:01:12 tx:3529/592872 rx:3623/579680
Tele 0/1/3 (8833) [0/1/3] tx:70585/70585/0ms g711ulaw noise:-67 acom:18  i/0:-70/-51 dBm
But on IP phones, I'm getting "unknown number".
Any idea about which configuration is missing?
Thank you!
2 Accepted Solutions
Chris Deren
What protocol are you using to control the GW? if MGCP caller ID is not supported until recent versions, if H323 do you have caller-id enable on the voice-port defined?
Chris
Sure, it is. Simply configure the GW with H323 as you can have both MGCP and H323 on the same GW as long as they don't control the same voice ports. Then add dial-peers on the GW and add H323 GW pointing to it on CUCM.
HTH, please rate all useful posts!
Chris
Chris Deren
Chris
Hi Chris,
Thank you for your answer.  You're right, it's MGCP.  Is it possible to change it to H323.  It will require many configurations?  It'll result in many changes?
Thank you!
Chris
Thank you Chris!  I'll try it!!!
