Forwarding hunt group
keith mulkey
We have a hunt group for our help desk, hunt pilot 3100. We will be closed for our Christmas party so we need to forward all calls to 3100 to a cell phone. Is there a way to do this, without changing 3100 to a translation pattern? The cluster is CUCM 10.
Thanks in advance.
Anas Abueideh
Level 9
Level 9
you can configure forward calls in the no answer to external number.
Anas
don't forget to rate helpful posts
5 Replies 5
Anas Abueideh
Level 9
Level 9
Anas
I've tried that by entering 91(outside number) in the "Destination" field for "Forward Unanswered Calls to" and I get "your call cannot be completed as dialed".
My mistake, that worked Anas...bad CSS...thank you!
Great,
thanks for the rating. if it is solved kindly mark the answer as correct.
it is more helpful for the community
regards
Anas
What you will have to do is configure a dummy DN Lets say 5555, and forward that to your cell. Then set your Hunt Pilots "Forward unanswered calls" to 5555.
