FXO always busy tone
Hi folks,
I am having a lot of issues setting up 6 FXOs on a 2901 GW running CME 8.6... The FXOs are in Nigeria. I have tryied LS and GS signaling (even though I am pretty sure it is LS), tryed different impedances and other parameters... So far the line goes "off-hook" for 1 seconds, I get a busy tone and then it goes back to "on-hook".
The only thing I am not sure is if they are using 2 or 4 pair wires... I've read that you should not use 4 wire cables as they can cause busy outs... only the central pair is used anyway, right ?
Any suggestions ?
Thanks!
15 Replies 15
Bruno Rangel
Have you configured Cptone under Voice Port?
Please Post your relevand config...
Cheers
Bruno Rangel
"Se você quiser alguém em quem confiar, confie em si mesmo. Quem acredita sempre alcança"
Renato Russo
Cheers
Bruno Rangel
Please remember to rate helpful responses using the star bellow and identify helpful or correct answers
Hi Bruno,
Sure, this is just one port.. the rest are the same:
voice-port 0/0/0
trunk-group POTS
cptone NG
connection plar 8296
caller-id enable
I'v also tryied different impedances...
HiJoan
Try this see if works:
voice-port 0/0/0
trunk-group POTS
cptone NG
timing sup-disconnect 85
impedance complex3
Cheers
Bruno Rangel
Renato Russo
Cheers
Bruno Rangel
Kevin Monteiro
Level 7
Level 7
Hi Joan,
Try re-creating the issue and capture the following debugs:
debug voip ccapi inout
debug vpm signal
debug voip ccap inout
Let me know the same.
-Regards,
Kevin
Hi Kevin,
I think the provider's equiment is faulty or not delivering enough voltage...  Taking a look a the debug vpm signal I see a "
[0/0/0, FXOLS_WAIT_DIAL_TONE, E_DSP_SIG_1100]fxols_power_denial_detected"
The customer assures that with a regular phone the line works.. What do you think ? and THANK YOU
Carlyle_VGW#
May  2 16:27:31.911: htsp_process_event: [50/0/9.1, EFXS_ONHOOK, E_DSP_SIG_1100]efxs_onhook_offhook htsp_setup_ind
May  2 16:27:31.911: [50/0/9.1] get_local_station_id calling num=8998 calling name=Guest4 calling time=05/02 17:27  orig called=
May  2 16:27:31.915: htsp_process_event: [50/0/9.1, EFXS_WAIT_SETUP_ACK, E_HTSP_SETUP_ACK]efxs_check_auto_call
May  2 16:27:32.719: htsp_digit_ready(50/0/9.1): digit = 9
May  2 16:27:32.719: htsp_digit_ready(50/0/9.1): digit = 1
May  2 16:27:32.719: htsp_digit_ready(50/0/9.1): digit = 2
May  2 16:27:32.979: htsp_digit_ready(50/0/9.1): digit = 7
May  2 16:27:33.435: htsp_digit_ready(50/0/9.1): digit = 8
May  2 16:27:33.435: htsp_digit_ready(50/0/9.1): digit = 2
May  2 16:27:33.435: htsp_digit_ready(50/0/9.1): digit = 9
May  2 16:27:33.695: htsp_digit_ready(50/0/9.1): digit = 4
May  2 16:27:38.695: htsp_timer_stop3
May  2 16:27:38.695: htsp_process_event: [50/0/9.1, EFXS_OFFHOOK, E_HTSP_PROCEEDING]efxs_offhook_proceeding
May  2 16:27:38.695: [50/0/9.1] set signal state = 0x8 timestamp = 0htsp_setup_req
May  2 16:27:38.695: htsp_process_event: [0/0/0, FXOLS_ONHOOK, E_HTSP_SETUP_REQ]fxols_onhook_setup
May  2 16:27:38.695: [0/0/0] set signal state = 0xC timestamp = 0
May  2 16:27:38.695: htsp_timer - 1300 msec
May  2 16:27:38.951: htsp_process_event: [0/0/0, FXOLS_WAIT_DIAL_TONE, E_DSP_SIG_1100]fxols_power_denial_detected
May  2 16:27:38.951: htsp_timer2 - 1000 msec
May  2 16:27:38.951: htsp_timer_stop
May  2 16:27:39.951: htsp_process_event: [0/0/0, FXOLS_WAIT_DIAL_TONE, E_HTSP_EVENT_TIMER2]fxols_power_den_disc
May  2 16:27:39.951: htsp_timer_stop
May  2 16:27:39.951: htsp_timer_stop2
May  2 16:27:39.951: [0/0/0] set signal state = 0x4 timestamp = 0
May  2 16:27:39.951: htsp_process_event: [0/0/0, FXOLS_ONHOOK, E_HTSP_RELEASE_REQ]fxols_onhook_release
Carlyle_VGW#
May  2 16:28:09.951: htsp_process_event: [50/0/9.1, EFXS_OFFHOOK, E_HTSP_RELEASE_REQ]efxs_offhook_disc
May  2 16:28:09.951: htsp_timer_stop
May  2 16:28:09.951: [50/0/9.1] set signal state = 0x4 timestamp = 0
May  2 16:28:09.951: [50/0/9.1] set signal state = 0xC timestamp = 0
May  2 16:28:09.951: [50/0/9.1] set signal state = 0x4 timestamp = 10
May  2 16:28:09.951: htsp_timer - 10 msec
May  2 16:28:09.963: htsp_process_event: [50/0/9.1, EFXS_CPC, E_HTSP_EVENT_TIMER]efxs_cpc_timer
May  2 16:28:09.963: htsp_timer - 30000 msec
May  2 16:28:09.963: htsp_process_event: [50/0/9.1, EFXS_WAIT_ONHOOK, E_DSP_SIG_0100]efxs_waitonhook_onhook
May  2 16:28:09.963: htsp_timer_stop htsp_report_onhook_sigCarlyle_VGW#
Carlyle_VGW#
Joan,
I had a similar issue with power denial detected. When a phone is connected it works however you cant make calls. From memory i think it truned out to be a faulty cable/bad cable/wrong cable pair
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Hi Juan,
Try adding the following command and shut no shut the FXO port:
config t
ME(config)#voice-port 0/2/0
CME(config-voiceport)#no b
CME(config-voiceport)#no bat
CME(config-voiceport)#no battery-reversal
CME(config-voiceport)#shu
CME(config-voiceport)#shut
CME(config-voiceport)#shutdown
CME(config-voiceport)#no shu
CME(config-voiceport)#no shutdown
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a00800ae2d1.shtml#topic5
This is the most common issue  FXO disconnect:
Power Denial-based Supervisory Disconnect
Power denial detection is an interruption of line power from the switch or PBX to the FXO port, which lasts at least 350 ms. The FXO interface on the router detects that power is no longer present and interprets this as a supervisory disconnect indication. This is available on the Cisco 1750, 2600, 3600, 3700 and MC3810 series router analog FXO ports in all versions of Cisco IOS which have voice support. This figure provides an illustration:
Battery Reversal
Battery reversal is implemented by reversing the battery polarity on the PBX. This is done initially when the call is connected (far-end answer), with the polarity reversed throughout the entire conversation. When the far-end disconnects, the battery polarity is changed back to normal to indicate call disconnect. PBX uses the battery reversal indication to start billing.
Note: Foreign Exchange Station (FXS) ports normally reverse the battery upon call connection. Therefore, if an FXS port is connected to an FXO port that does not support battery reversal detection, you should disable battery reversal on the FXS port to prevent unexpected behavior.
Kindly rate this post accordingly.
-Regards,
Kevin Monteiro
Hi Kevin,
That is the firts thing I tryied.. no luck.. Moreover, when I do an Inbound call I don't see anything at all on the debug vpm signal.. the port never tryies to go off-hook either
Hi Joan,
if you dont mind can you attach the show tech with show voice port 0/0/0.
I would want tohave a look at it.
-Regards,
Kevin Monteiro
Hi Joan,
Along with the show tech and show voice port 0/0/0 i would require show voice dsp group all.
-Regards,
Kevin
Hi Kevin,
Here are the outputs except from the show tech because I am not allowed to share that output... :-(
#show voice dsp group all
DSP groups on slot 0:
dsp 1:
  State: UP, firmware: 28.3.5
  Max signal/voice channel: 16/16
  Max credits: 240, Voice credits: 240, Video credits: 0
  num_of_sig_chnls_allocated: 8
  Transcoding channels allocated: 2
  Group: FLEX_GROUP_VOICE, complexity: FLEX
    Shared credits: 192, reserved credits: 0
    Signaling channels allocated: 8
    Voice channels allocated: 0
    Credits used (rounded-up): 0
  Group: FLEX_GROUP_XCODE, complexity: HIGH
    Shared credits: 0, reserved credits: 48
    Transcoding channels allocated: 0
  Slot: 0
  Device idx: 0
  PVDM Slot: 0
  Dsp Type: SP2600
DSP groups on slot 1:
This command is not applicable to slot 1
  0 DSP resource allocation failure
Foreign Exchange Office 0/0/0 Slot is 0, Sub-unit is 0, Port is 0
Type of VoicePort is FXO
Operation State is DORMANT
Administrative State is UP
The Last Interface Down Failure Cause is Administrative Shutdown
Description is not set
Noise Regeneration is enabled
Non Linear Processing is enabled
Non Linear Mute is disabled
Non Linear Threshold is -21 dB
Music On Hold Threshold is Set to -38 dBm
In Gain is Set to 0 dB
Out Attenuation is Set to 3 dB
Echo Cancellation is enabled
Echo Cancellation NLP mute is disabled
Echo Cancellation NLP threshold is -21 dB
Echo Cancel Coverage is set to 128 ms
Echo Cancel worst case ERL is set to 6 dB
Playout-delay Mode is set to adaptive
Playout-delay Nominal is set to 60 ms
Playout-delay Maximum is set to 1000 ms
Playout-delay Minimum mode is set to default, value 40 ms
Playout-delay Fax is set to 300 ms
Connection Mode is plar
Connection Number is 8998
Initial Time Out is set to 15 s
Interdigit Time Out is set to 10 s
Call Disconnect Time Out is set to 60 s
Power Denial Disconnect Time Out is set to 1000 ms
Ringing Time Out is set to 180 s
Wait Release Time Out is set to 30 s
Companding Type is u-law
Region Tone is set for NG
Analog Info Follows:
Currently processing none
Maintenance Mode Set to None (not in mtc mode)
Number of signaling protocol errors are 0
Impedance is set to complex3 Ohm
Station name None, Station number None
Translation profile (Incoming):
Translation profile (Outgoing):
lpcor (Incoming):
lpcor (Outgoing):
Voice card specific Info Follows:
Signal Type is loopStart
Battery-Reversal is disabled
Number Of Rings is set to 1
Supervisory Disconnect is signal
Answer Supervision is inactive
Hook Status is On Hook
Ring Detect Status is inactive
Ring Ground Status is inactive
Tip Ground Status is inactive
Dial Out Type is dtmf
Digit Duration Timing is set to 100 ms
InterDigit Duration Timing is set to 100 ms
Pulse Rate Timing is set to 10 pulses/second
InterDigit Pulse Duration Timing is set to 750 ms
Percent Break of Pulse is 65 percent
GuardOut timer is 2000 ms
Minimum ring duration timer is 125 ms
Hookflash-in Timing is set to 600 ms
Hookflash-out Timing is set to 400 ms
Supervisory Disconnect Timing (loopStart only) is set to 85 ms
OPX Ring Wait Timing is set to 6000 ms
Secondary dialtone is disabled
Hi Joan,
I would just request you make a testcall and capture these debugs again.
Paste the debugs in the notepad.
debug vpm signal
debug voip vtsp all
config t
logg buff 500000000 deb
no logg mon
no logg con
logg on
ter no mon
clear log
show log
Make a test call and capture the debugs.
-Regards,
Kevin
Here you go
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2013.05.02 12:14:23 =~=~=~=~=~=~=~=~=~=~=~=
Carlyle_VGW#
Carlyle_VGW#debug voip ccapi inout
voip ccapi inout debugging is on
Carlyle_VGW#debug vpm signal
Voice Port Module signaling debugging is enabled
Carlyle_VGW#debug voip vtsp all
voip vtsp all debugging is on
Carlyle_VGW#ter
Carlyle_VGW#terminal mon
Carlyle_VGW#terminal monitor
Carlyle_VGW#
Carlyle_VGW#
Carlyle_VGW#
Carlyle_VGW#
Carlyle_VGW#
Carlyle_VGW#
Carlyle_VGW#
May  2 19:15:03.968: htsp_process_event: [50/0/9.1, EFXS_ONHOOK, E_DSP_SIG_1100]efxs_onhook_offhook htsp_setup_ind
May  2 19:15:03.968: [50/0/9.1] get_local_station_id calling num=8998 calling name=Guest4 calling time=05/02 20:15  orig called=
May  2 19:15:03.972: //-1/xxxxxxxxxxxx/VTSP:(50/0/9):-1:-1:-1/vtsp_allocate_cdb:
   CDB=0x2A64EE18
May  2 19:15:03.972: //-1/xxxxxxxxxxxx/VTSP:(50/0/9):-1:-1:-1/vtsp_do_call_setup_ind:
   Event=E_TSP_SETUP_IND
   Progress Indication=3, CarrierIDCode=, Info Trans Capability=0, Source Carrier ID=, tg_label_flag=0
   Calling Number=8998, TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed
   CLIR=FALSE, CLID Transparent=FALSE, Null Originating Calling Number=FALSE, Calling Translated=FALSE
May  2 19:15:03.972: //-1/6D63AF058016/VTSP:(50/0/9):-1:-1:-1/vtsp_do_normal_call_setup_ind:
May  2 19:15:03.972: //-1/6D63AF058016/VTSP:(50/0/9):-1:-1:-1/vtsp_timer:
   Timer Start Time=2436434, Timer Value=180000(ms)
   IC State Machine (ICSM) Added
May  2 19:15:03.972: //-1/6D63AF058016/VTSP:(50/0/9):-1:-1:-1/vtsp_insert_cdb:
May  2 19:15:03.972: //-1/6D63AF058016/VTSP:(50/0/9):-1:0:65/vtsp_dsm_opened_cb:
May  2 19:15:03.972: //-1/6D63AF058016/VTSP:(50/0/9):-1:0:65/vtsp_process_event:
   [state:S_SETUP_IND_PEND, event:E_VTSP_DSM_OPEN_SUCCESS]
May  2 19:15:03.972: //-1/6D63AF058016/VTSP:(50/0/9):-1:0:65/act_setup_ind_pend_success:
May  2 19:15:03.972: //-1/6D63AF058016/VTSP:(50/0/9):-1:0:65/vtsp_realloc_cdb:
   CDB=0x2A64EE18
May  2 19:15:03.972: //-1/6D63AF058016/VTSP:(50/0/9):-1:0:65/vtsp_indicate_call:
May  2 19:15:03.972: //-1/6D63AF058016/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=8998
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=0   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
May  2 19:15:03.972: //-1/6D63AF058016/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x31A9C0FC, Call Info(
   Calling Number=8998,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
   Incoming Dial-peer=20009, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
May  2 19:15:03.972: //-1/6D63AF058016/CCAPI/ccCheckClipClir:
   In: Calling Number=8998(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=8998(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
May  2 19:15:03.972: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
May  2 19:15:03.972: :cc_get_feature_vsa malloc success
May  2 19:15:03.972:  cc_get_feature_vsa count is 1
May  2 19:15:03.972: :FEATURE_VSA attributes are: feature_name:0,feature_time:711176472,feature_id:9
May  2 19:15:03.972: //9/6D63AF058016/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=8998(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown))
May  2 19:15:03.972: //9/6D63AF058016/VTSP:(50/0/9):-1:0:65/vtsp_insert_cdb:
May  2 19:15:03.972: //9/6D63AF058016/VTSP:(50/0/9):-1:0:65/vtsp_timer:
May  2 19:15:03.972: //9/6D63AF058016/CCAPI/cc_process_call_setup_ind:
   Event=0x2B4E96B0
May  2 19:15:03.972: //9/6D63AF058016/CCAPI/ccCallSetContext:
   Context=0x304C35A8
May  2 19:15:03.976: //9/6D63AF058016/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 9 with tag 20009 to app "_ManagedAppProcess_Default"
May  2 19:15:03.976: //9/6D63AF058016/CCAPI/ccCallSetupAck:
   Call Id=9
May  2 19:15:03.976: //9/6D63AF058016/CCAPI/cc_api_set_transfer_info:
   Transfer Number=, Transfer Reason=0x0
May  2 19:15:03.976: //9/6D63AF058016/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=TRUE, Tone=Dial Tone,
   Tone Direction=Network, Params=0x0, Call Id=9
May  2 19:15:03.976: //9/6D63AF058016/CCAPI/ccSetDigitTimeouts:
   Initial Digit Timeout=-1000(ms), Inter Digit Timeout=-1000(ms)
   Call Entry(Inter Digit Timeout=10000(ms), Initial Digit Timeout=10000(ms))
May  2 19:15:03.976: //9/6D63AF058016/CCAPI/ccCallReportDigits:
   (callID=0x9, digit_event=0x1, enable=TRUE, consume=FALSE)
   Enabled=TRUE, Call Id=9
May  2 19:15:03.976: //9/6D63AF058016/VTSP:(50/0/9):-1:0:65/vtsp_report_digit_control:
May  2 19:15:03.976: //9/6D63AF058016/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x31A9C0FC, callID=0x9, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
   Enabled=TRUE, Disposition=0x0, Interface=0x31A9C0FC, Call Id=9
   Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=5000(ms))
   Digit Reporting=TRUE
May  2 19:15:03.976: //9/6D63AF058016/VTSP:(50/0/9):-1:0:65/vtsp_process_event:
   [state:S_SETUP_INDICATED, event:E_CC_SETUP_ACK]
May  2 19:15:03.976: //9/6D63AF058016/VTSP:(50/0/9):-1:0:65/act_setup_ind_ack:
   Fax Relay=TRUE, Dial Tone=TRUE, Digit Collect=TRUE, Overlap=FALSE, DID=FALSE
May  2 19:15:03.976: //9/6D63AF058016/VTSP:(50/0/9):-1:0:65/vtsp_timer_stop:
   Timer Stop Time=2436434
May  2 19:15:03.976: htsp_process_event: [50/0/9.1, EFXS_WAIT_SETUP_ACK, E_HTSP_SETUP_ACK]efxs_check_auto_call
May  2 19:15:04.704: //9/6D63AF058016/VTSP:(50/0/9):-1:0:65/vtsp_dsm_digit_begin_cb:
May  2 19:15:04.708: //9/6D63AF058016/VTSP:(50/0/9):-1:0:65/vtsp_dsm_digit_begin_cb:
   Begin Digit=9
   Digit Reporting=TRUE, Digit Consume=FALSE, Digit Relay=TRUE
May  2 19:15:04.708: //9/6D63AF058016/CCAPI/cc_api_call_digit_begin:
   Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
   Source Call Id=9, Digit=9, DigitBeginFlags=0x0,
   Rtp Timestamp=0x11E608, Rtp Expiration=0x0
May  2 19:15:04.708: //9/6D63AF058016/VTSP:(50/0/9):-1:0:65/vtsp_dsm_digit_end_cb:
May  2 19:15:04.708: //9/6D63AF058016/VTSP:(50/0/9):-1:0:65/vtsp_timer_stop:
   Timer Stop Time=2436508
   End Digit=9
May  2 19:15:04.708: //9/6D63AF058016/CCAPI/cc_api_call_digit_end:
   Source Call Id=9, Digit=9, Duration=100,
   Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
   Call Entry(Handoff Depth=0)
May  2 19:15:04.708: htsp_digit_ready(50/0/9.1): digit = 9
   Begin Digit=1
   Source Call Id=9, Digit=1, DigitBeginFlags=0x0,
   Rtp Timestamp=0x126308, Rtp Expiration=0x0
   End Digit=1
   Source Call Id=9, Digit=1, Duration=100,
May  2 19:15:04.708: htsp_digit_ready(50/0/9.1): digit = 1
May  2 19:15:04.960: //9/6D63AF058016/VTSP:(50/0/9):-1:0:65/vtsp_dsm_digit_begin_cb:
   Begin Digit=2
May  2 19:15:04.960: //9/6D63AF058016/CCAPI/cc_api_call_digit_begin:
   Source Call Id=9, Digit=2, DigitBeginFlags=0x0,
   Rtp Timestamp=0x12E008, Rtp Expiration=0x0
May  2 19:15:04.960: //9/6D63AF058016/VTSP:(50/0/9):-1:0:65/vtsp_dsm_digit_end_cb:
May  2 19:15:04.960: //9/6D63AF058016/VTSP:(50/0/9):-1:0:65/vtsp_timer_stop:
   Timer Stop Time=2436533
   End Digit=2
May  2 19:15:04.960: //9/6D63AF058016/CCAPI/cc_api_call_digit_end:
   Source Call Id=9, Digit=2, Duration=100,
May  2 19:15:04.960: htsp_digit_ready(50/0/9.1): digit = 2
   Begin Digit=7
   Source Call Id=9, Digit=7, DigitBeginFlags=0x0,
   Rtp Timestamp=0x135D08, Rtp Expiration=0x0
   End Digit=7
   Source Call Id=9, Digit=7, Duration=100,
May  2 19:15:04.960: htsp_digit_ready(50/0/9.1): digit = 7
May  2 19:15:05.412: //9/6D63AF058016/VTSP:(50/0/9):-1:0:65/vtsp_dsm_digit_begin_cb:
   Begin Digit=7
May  2 19:15:05.412: //9/6D63AF058016/CCAPI/cc_api_call_digit_begin:
   Rtp Timestamp=0x13DA08, Rtp Expiration=0x0
May  2 19:15:05.412: //9/6D63AF058016/VTSP:(50/0/9):-1:0:65/vtsp_dsm_digit_end_cb:
May  2 19:15:05.412: //9/6D63AF058016/VTSP:(50/0/9):-1:0:65/vtsp_timer_stop:
   Timer Stop Time=2436578
   End Digit=7
May  2 19:15:05.412: //9/6D63AF058016/CCAPI/cc_api_call_digit_end:
May  2 19:15:05.412: htsp_digit_ready(50/0/9.1): digit = 7
   Begin Digit=8
   Source Call Id=9, Digit=8, DigitBeginFlags=0x0,
   Rtp Timestamp=0x145708, Rtp Expiration=0x0
   End Digit=8
   Source Call Id=9, Digit=8, Duration=100,
May  2 19:15:05.412: htsp_digit_ready(50/0/9.1): digit = 8
May  2 19:15:05.416: //9/6D63AF058016/VTSP:(50/0/9):-1:0:65/vtsp_dsm_digit_begin_cb:
   Begin Digit=2
May  2 19:15:05.416: //9/6D63AF058016/CCAPI/cc_api_call_digit_begin:
   Rtp Timestamp=0x14D408, Rtp Expiration=0x0
May  2 19:15:05.416: //9/6D63AF058016/VTSP:(50/0/9):-1:0:65/vtsp_dsm_digit_end_cb:
May  2 19:15:05.416: //9/6D63AF058016/VTSP:(50/0/9):-1:0:65/vtsp_timer_stop:
   End Digit=2
May  2 19:15:05.416: //9/6D63AF058016/CCAPI/cc_api_call_digit_end:
May  2 19:15:05.416: htsp_digit_ready(50/0/9.1): digit = 2
   Begin Digit=9
   Rtp Timestamp=0x155108, Rtp Expiration=0x0
   End Digit=9
May  2 19:15:05.416: htsp_digit_ready(50/0/9.1): digit = 9
May  2 19:15:05.668: //9/6D63AF058016/VTSP:(50/0/9):-1:0:65/vtsp_dsm_digit_begin_cb:
   Begin Digit=4
May  2 19:15:05.668: //9/6D63AF058016/CCAPI/cc_api_call_digit_begin:
   Source Call Id=9, Digit=4, DigitBeginFlags=0x0,
   Rtp Timestamp=0x15CE08, Rtp Expiration=0x0
May  2 19:15:05.668: //9/6D63AF058016/VTSP:(50/0/9):-1:0:65/vtsp_dsm_digit_end_cb:
May  2 19:15:05.668: //9/6D63AF058016/VTSP:(50/0/9):-1:0:65/vtsp_timer_stop:
   Timer Stop Time=2436604
   End Digit=4
May  2 19:15:05.668: //9/6D63AF058016/CCAPI/cc_api_call_digit_end:
   Source Call Id=9, Digit=4, Duration=100,
May  2 19:15:05.668: htsp_digit_ready(50/0/9.1): digit = 4
May  2 19:15:10.668: //9/6D63AF058016/CCAPI/cc_handle_inter_digit_timer:
   Generate inter-digit timeout CC_EV_CALL_DIGIT_END event
May  2 19:15:10.668: //9/6D63AF058016/CCAPI/ccCallReportDigits:
   (callID=0x9, digit_event=0x0, enable=FALSE, consume=FALSE)
May  2 19:15:10.668: //9/6D63AF058016/VTSP:(50/0/9):-1:0:65/vtsp_report_digit_control:
May  2 19:15:10.668: //9/6D63AF058016/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x31A9C0FC, callID=0x9, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
   Digit Reporting=FALSE
May  2 19:15:10.668: //9/6D63AF058016/CCAPI/ccCallProceeding:
   Progress Indication=NULL(0)
May  2 19:15:10.668: //9/6D63AF058016/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=10, Params=0x304C4AB8, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
May  2 19:15:10.668: //9/6D63AF058016/CCAPI/cc_fill_tg_params:
   Not a cic call
   Trunk Group Select Interface Success;
   Interface=0x2B541470, Selected Interface=1, Selected DSL=-1
May  2 19:15:10.668: //9/6D63AF058016/CCAPI/ccCheckClipClir:
   Destination Pattern=9T, Called Number=912778294, Digit Strip=TRUE
   Called Number=912778294(TON=Unknown, NPI=Unknown),
   Redirect Number=, Display Info=Guest4
   Account Number=, Final Destination Flag=FALSE,
   Guid=6D63AF05-B293-11E2-8016-9FBC04AB56B6, Outgoing Dial-peer=10
May  2 19:15:10.668: //9/6D63AF058016/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=8998
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=912778294
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
May  2 19:15:10.668: //9/6D63AF058016/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x2B541470, Interface Type=6, Destination=, Mode=0x0,
   Call Params(Calling Number=8998,(Calling Name=Guest4)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=912778294(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE, Outgoing Dial-peer=10, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=POTS, tg_label_flag=2, Application Call Id=)
May  2 19:15:10.668: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
May  2 19:15:10.668: :cc_get_feature_vsa malloc success
May  2 19:15:10.668:  cc_get_feature_vsa count is 2
May  2 19:15:10.668: :FEATURE_VSA attributes are: feature_name:0,feature_time:711176248,feature_id:10
May  2 19:15:10.668: //-1/xxxxxxxxxxxx/VTSP:(0/0/0):-1:-1:-1/vtsp_allocate_cdb:
   CDB=0x2A64EB40
May  2 19:15:10.668: //-1/xxxxxxxxxxxx/VTSP:(0/0/0):-1:-1:-1/vtsp_insert_cdb:
May  2 19:15:10.668: //9/6D63AF058016/VTSP:(50/0/9):-1:0:65/vtsp_spi_event_handler:
   Event Category=1, Event=176
May  2 19:15:10.668: //10/6D63AF058016/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
   Trunk Group Call Setting;
   Call Entry(Retry Count=0, Voice Class Cause Code=0)
May  2 19:15:10.668: //10/6D63AF058016/CCAPI/ccCallSetContext:
   Context=0x304C4A68
May  2 19:15:10.668: //9/6D63AF058016/CCAPI/ccSaveDialpeerTag:
May  2 19:15:10.672: //9/6D63AF058016/VTSP:(50/0/9):-1:0:65/vtsp_process_event:
   [state:S_DIGIT_COLLECT, event:E_CC_PROCEEDING]
May  2 19:15:10.672: //9/6D63AF058016/VTSP:(50/0/9):-1:0:65/act_dcollect_proc:
May  2 19:15:10.672: //-1/xxxxxxxxxxxx/VTSP:(0/0/0):-1:-1:-1/vtsp_process_event:
   [state:INVALID STATE MACHINE, event:E_CC_SETUP_REQ]
May  2 19:15:10.672: //10/xxxxxxxxxxxx/VTSP:(0/0/0):-1:-1:-1/vtsp_og_call_req:
May  2 19:15:10.672: //9/6D63AF058016/CCAPI/cc_api_modify_tgt_cid_call_active_record:
   Target Trkgrp Route Label=POTS, tg_label_flag=TRUE, Call Id=0x9
May  2 19:15:10.672: htsp_timer_stop3
May  2 19:15:10.672: //10/6D63AF058016/VTSP:(0/0/0):-1:-1:-1/vtsp_og_call_req:
   Echo Cancel=TRUE, Gain Control=0
   Auto Gain Control=FALSE, Dual Tone Detect Mask=0x0, Seq Tone Detect=FALSE
May  2 19:15:10.672: //10/6D63AF058016/VTSP:(0/0/0):-1:-1:-1/vtsp_do_call_setup_req:
May  2 19:15:10.672: htsp_process_event: [50/0/9.1, EFXS_OFFHOOK, E_HTSP_PROCEEDING]efxs_offhook_proceeding
May  2 19:15:10.672: [50/0/9.1] set signal state = 0x8 timestamp = 0
May  2 19:15:10.672: //10/6D63AF058016/VTSP:(0/0/0):-1:1:1/vtsp_dsm_opened_cb:
May  2 19:15:10.672: //10/6D63AF058016/VTSP:(0/0/0):-1:1:1/vtsp_process_event:
   [state:S_SETUP_REQ_PEND, event:E_VTSP_DSM_OPEN_SUCCESS]
May  2 19:15:10.672: //10/6D63AF058016/VTSP:(0/0/0):-1:1:1/act_setup_req_pend_succ:
May  2 19:15:10.672: //10/6D63AF058016/VTSP:(0/0/0):-1:1:1/vtsp_request_call:
   Mode=0, Peer=10
May  2 19:15:10.672: digit_strip:1, pcn:912778294, poa:9T
May  2 19:15:10.672: pcn:12778294, poa:T
May  2 19:15:10.672: Final pcn:12778294, poa:T, dial_string:12778294
May  2 19:15:10.672: //10/6D63AF058016/VTSP:(0/0/0):-1:1:1/vtsp_create_call_active_on_setup_req:
   Source Trkgrp Route Label=htsp_setup_req
   Progress Indication=3, Info Trans Capability=0
   Called Number=912778294, TON=Unknown, NPI=Unknown
May  2 19:15:10.672: htsp_process_event: [0/0/0, FXOLS_ONHOOK, E_HTSP_SETUP_REQ]fxols_onhook_setup
May  2 19:15:10.672: [0/0/0] set signal state = 0xC timestamp = 0
May  2 19:15:10.672: htsp_timer - 1300 msec
   [state:S_SETUP_REQUEST, event:E_TSP_PROCEEDING]
May  2 19:15:10.672: //10/6D63AF058016/VTSP:(0/0/0):-1:1:1/act_setup_pend_proceeding:
May  2 19:15:10.672: //10/6D63AF058016/VTSP:(0/0/0):-1:1:1/vtsp_timer:
   Timer Start Time=2437104, Timer Value=25000(ms)
May  2 19:15:10.672: //10/6D63AF058016/CCAPI/cc_api_call_proceeding:
   Interface=0x2B541470, Progress Indication=NULL(0)
   Peer=10, Progress Indication=0, Return Code=2
May  2 19:15:10.676: //10/6D63AF058016/VTSP:(0/0/0):-1:1:1/vtsp_dsm_opened_cb:
May  2 19:15:10.676: //10/6D63AF058016/VTSP:(0/0/0):-1:1:1/vtsp_process_event:
   [state:S_NULL, event:E_VTSP_DSM_OPEN_SUCCESS]
May  2 19:15:10.676: //10/6D63AF058016/VTSP:(0/0/0):-1:1:1/act_setup_req_wait_pend_success:
   Event=75
May  2 19:15:10.676: //10/6D63AF058016/VTSP:(0/0/0):-1:1:1/vtsp_timer_stop:
   Timer Stop Time=2437104
May  2 19:15:10.928: htsp_process_event: [0/0/0, FXOLS_WAIT_DIAL_TONE, E_DSP_SIG_1100]fxols_power_denial_detected
May  2 19:15:10.928: htsp_timer2 - 1000 msec
May  2 19:15:10.928: htsp_timer_stop
May  2 19:15:11.928: htsp_process_event: [0/0/0, FXOLS_WAIT_DIAL_TONE, E_HTSP_EVENT_TIMER2]fxols_power_den_disc
May  2 19:15:11.928: htsp_timer_stop
May  2 19:15:11.928: htsp_timer_stop2
May  2 19:15:11.928: [0/0/0] set signal state = 0x4 timestamp = 0
May  2 19:15:11.928: //10/6D63AF058016/VTSP:(0/0/0):-1:1:1/vtsp_process_event:
   [state:S_SETUP_REQ_PROC, event:E_TSP_DISCONNECT_IND]
May  2 19:15:11.928: //10/6D63AF058016/VTSP:(0/0/0):-1:1:1/act_setup_pend_release_ind:
   Cause Value=34
May  2 19:15:11.928: //10/6D63AF058016/VTSP:(0/0/0):-1:1:1/vtsp_ring_noan_timer_stop:
   Timer Stop Time=2437230
May  2 19:15:11.928: //10/6D63AF058016/VTSP:(0/0/0):-1:1:1/vtsp_cc_call_disconnected:
   Cause Value=34
May  2 19:15:11.928: //10/6D63AF058016/CCAPI/cc_api_call_disconnected:
   Cause Value=34, Interface=0x2B541470, Call Id=10
   Call Entry(Responsed=TRUE, Cause Value=34, Retry Count=0)
May  2 19:15:11.928: //10/6D63AF058016/VTSP:(0/0/0):-1:1:1/vtsp_set_release_source:
   Release Direction=PSTN, Release Source=Called Party-PSTN
   Peer=10
May  2 19:15:11.928: //9/6D63AF058016/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
May  2 19:15:11.928: //10/6D63AF058016/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=10
May  2 19:15:11.928: //10/6D63AF058016/CCAPI/ccCallDisconnect:
   Cause Value=34, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=34)
   Cause Value=34, Call Entry(Responsed=TRUE, Cause Value=34)
May  2 19:15:11.928: //10/6D63AF058016/VTSP:(0/0/0):-1:1:1/vtsp_call_disconnect:
   [Out Of Service]-Tone Played In Direction [Both]
   [state:S_WAIT_HOST_DISC, event:E_CC_DISCONNECT]
May  2 19:15:11.928: //10/6D63AF058016/VTSP:(0/0/0):-1:1:1/act_host_disc_cleanup:
   dsm_indicate_error=0, short_cleardown_timeout=0, Mode=0
   Exit State=16
May  2 19:15:11.928: //10/6D63AF058016/VTSP:(0/0/0):-1:1:1/vtsp_dsm_get_levels_done_cb:
   [state:S_WAIT_STATS, event:E_VTSP_DSM_STATS_COMPLETE]
May  2 19:15:11.928: //10/6D63AF058016/VTSP:(0/0/0):-1:1:1/act_dsm_dsp_stats_complete:
May  2 19:15:11.928: //10/6D63AF058016/VTSP:(0/0/0):-1:1:1/vtsp_timer:
   Timer Start Time=2437230, Timer Value=60000(ms)
   [state:S_WAIT_RELEASE, event:E_VTSP_DSM_STATS_COMPLETE]
   Unexpected EVENT [E_VTSP_DSM_STATS_COMPLETE] Received For STATE [S_WAIT_RELEASE];
   Previous STATE [0.16 ]
May  2 19:15:11.928: htsp_process_event: [0/0/0, FXOLS_ONHOOK, E_HTSP_RELEASE_REQ]fxols_onhook_release
   [state:S_WAIT_RELEASE, event:E_TSP_DISCONNECT_CONF]
May  2 19:15:11.928: //10/6D63AF058016/VTSP:(0/0/0):-1:1:1/act_wrelease_release:
May  2 19:15:11.928: //10/6D63AF058016/VTSP:(0/0/0):-1:1:1/vtsp_play_busy_timer_stop:
May  2 19:15:11.928: //10/6D63AF058016/VTSP:(0/0/0):-1:1:1/vtsp_timer_stop:
May  2 19:15:11.928: //10/6D63AF058016/VTSP:(0/0/0):-1:1:1/vtsp_do_call_history:
   Coder Rate=-1
May  2 19:15:11.932: //10/6D63AF058016/VTSP:(0/0/0):-1:1:1/vtsp_is_valid_dsm_handle:
   DMGR=0x2AD73208, VTSP CDB=0x2A64EB40
May  2 19:15:11.932: //10/6D63AF058016/VTSP:(0/0/0):-1:-1:-1/vtsp_dsm_closed_cb:
May  2 19:15:11.932: //10/6D63AF058016/VTSP:(0/0/0):-1:-1:-1/vtsp_process_event:
   [state:S_CLOSE_DSPRM, event:E_VTSP_DSM_CLOSE_COMPLETE]
May  2 19:15:11.932: //10/6D63AF058016/VTSP:(0/0/0):-1:-1:-1/act_terminate:
May  2 19:15:11.932: //10/6D63AF058016/VTSP:(0/0/0):-1:-1:-1/vtsp_timer_stop:
May  2 19:15:11.932: //10/6D63AF058016/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x2B541470, Tag=0x0, Call Id=10,
   Call Entry(Disconnect Cause=34, Voice Class Cause Code=0, Retry Count=0)
   tg for this call is POTS success/fail is 0
   Call Disconnect Event Sent
May  2 19:15:11.932: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
May  2 19:15:11.932: :cc_free_feature_vsa freeing 2A63B030
May  2 19:15:11.932:  vsacount in free is 1
May  2 19:15:11.932: //-1/6D63AF058016/VTSP:(0/0/0):-1:-1:-1/vtsp_free_cdb:
   CDB=0x2A64EB40
May  2 19:15:11.932: //9/6D63AF058016/CCAPI/ccCallDisconnect:
   Cause Value=34, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
May  2 19:15:11.932: //9/6D63AF058016/VTSP:(50/0/9):-1:0:65/vtsp_call_disconnect:
May  2 19:15:11.932: //9/6D63AF058016/VTSP:(50/0/9):-1:0:65/vtsp_process_event:
   [state:S_PROCEEDING, event:E_CC_DISCONNECT]
May  2 19:15:11.932: //9/6D63AF058016/VTSP:(50/0/9):-1:0:65/act_pre_con_disconnect:
   Cause Value=34, Hairpin=FALSE
May  2 19:15:11.932: //9/6D63AF058016/VTSP:(50/0/9):-1:0:65/vtsp_timer_stop:
May  2 19:15:11.932: //9/6D63AF058016/VTSP:(50/0/9):-1:0:65/vtsp_ring_noan_timer_stop:
   [Out Of Service]-Tone Played In Direction [Network]
May  2 19:15:11.932: //9/6D63AF058016/VTSP:(50/0/9):-1:0:65/vtsp_play_busy_timer_start:
   Timer Start Time=2437230, Busy Timer Value=30(ms)
   Tone=Out Of Service, Tone Timeout=30(s), Progress Indication Sent=0
May  2 19:15:23.268: htsp_process_event: [50/0/9.1, EFXS_OFFHOOK, E_DSP_SIG_0100]efxs_offhook_onhook
May  2 19:15:23.268: htsp_timer - 10 msec
May  2 19:15:23.280: htsp_process_event: [50/0/9.1, EFXS_OFFHOOK, E_HTSP_EVENT_TIMER]efxs_offhook_timer
May  2 19:15:23.280: //9/6D63AF058016/VTSP:(50/0/9):-1:0:65/vtsp_process_event:
   [state:S_WAIT_RELEASE_NC, event:E_TSP_DISCONNECT_IND]
May  2 19:15:23.280: //9/6D63AF058016/VTSP:(50/0/9):-1:0:65/act_pre_con_disc_rel:
   Cause Value=34
May  2 19:15:23.280: htsp_process_event: [50/0/9.1, EFXS_ONHOOK, E_HTSP_RELEASE_REQ]efxs_onhook_release
May  2 19:15:23.280: htsp_timer_stop
May  2 19:15:23.280: [50/0/9.1] set signal state = 0x4 timestamp = 0
   [state:S_WAIT_RELEASE_RESP, event:E_TSP_DISCONNECT_CONF]
May  2 19:15:23.280: //9/6D63AF058016/VTSP:(50/0/9):-1:0:65/act_wrelease_release:
May  2 19:15:23.280: //9/6D63AF058016/VTSP:(50/0/9):-1:0:65/vtsp_play_busy_timer_stop:
   Timer Stop Time=2438365
May  2 19:15:23.280: //9/6D63AF058016/VTSP:(50/0/9):-1:0:65/vtsp_timer_stop:
May  2 19:15:23.280: //9/6D63AF058016/VTSP:(50/0/9):-1:0:65/vtsp_do_call_history:
   Coder Rate=-1
May  2 19:15:23.280: //9/6D63AF058016/VTSP:(50/0/9):-1:0:65/vtsp_is_valid_dsm_handle:
   DMGR=0x2AD764A4, VTSP CDB=0x2A64EE18
May  2 19:15:23.280: //9/6D63AF058016/VTSP:(50/0/9):-1:-1:-1/vtsp_dsm_closed_cb:
May  2 19:15:23.280: //9/6D63AF058016/VTSP:(50/0/9):-1:-1:-1/vtsp_process_event:
May  2 19:15:23.280: //9/6D63AF058016/VTSP:(50/0/9):-1:-1:-1/act_terminate:
May  2 19:15:23.280: //9/6D63AF058016/VTSP:(50/0/9):-1:-1:-1/vtsp_timer_stop:
May  2 19:15:23.280: //9/6D63AF058016/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x31A9C0FC, Tag=0x0, Call Id=9,
May  2 19:15:23.280: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
May  2 19:15:23.280: :cc_free_feature_vsa freeing 2A63B110
May  2 19:15:23.280:  vsacount in free is 0
May  2 19:15:23.280: //-1/6D63AF058016/VTSP:(50/0/9):-1:-1:-1/vtsp_free_cdb:
   CDB=0x2A64EE18
Carlyle_VGW#
Carlyle_VGW#
Carlyle_VGW#
Carlyle_VGW#
Hi Joan,
This is a 100% Service-provider issue. There is a issue with the cabling from the SP.
The cause code  34 means = no circuit (34).
Contact your SP, they should fix the issue.
-Regards,
Kevin
