11-15-2020 11:24 AM
The scenario is customer has two analog lines and the router come with SM-X-16FXS/2FXO card. Is it possible two connect only the two analog lines with amphenol connector.
SM-X-16FXS/2FXO--How many FXO lines i can connect on which port.
11-15-2020 02:16 PM
The product documentation has those details, have you reviewed it???
11-16-2020 11:02 PM
Jaime Thanks for your prompt response,
I need to clarify , Only 2 Analog line will able to connected, Could you suggest me an Amphoneal connector to connect the 2 analog line.
11-17-2020 09:11 AM
You need Amphoneal cable for connection out.
11-16-2020 10:45 PM
As the name has 2FXO in it that would be the number of FXO lines that you can connect. One line per port.
11-16-2020 11:03 PM
I am bit confused, Not sure where to connect the analog lines in the connector.
11-17-2020 06:45 AM
That's where reading the product documentation comes in...
11-17-2020 08:53 AM
As Java wrote this is detailed in the documentation. Pretty sure that you would find it with minimal amount of effort from your end.
