FXO Card Clarification
Siva chinap
Level 5
Level 5
The scenario is customer has two analog lines and the router come with SM-X-16FXS/2FXO card. Is it possible two connect only the two analog lines with amphenol connector.
SM-X-16FXS/2FXO--How many FXO lines i can connect on which port.
7 Replies 7
Jaime Valencia
The product documentation has those details, have you reviewed it???
java
if this helps, please rate
Jaime Thanks for your prompt response,
I need to clarify , Only 2 Analog line will able to connected, Could you suggest me an Amphoneal connector to connect the 2 analog line.
You need Amphoneal cable for connection out.
Response Signature
As the name has 2FXO in it that would be the number of FXO lines that you can connect. One line per port.
Response Signature
@Roger Kallberg
I am bit confused, Not sure where to connect the analog lines in the connector.
That's where reading the product documentation comes in...
java
As Java wrote this is detailed in the documentation. Pretty sure that you would find it with minimal amount of effort from your end.
Response Signature
