FXO Inbound problem
Hey everybody
          I have some problem that I have never found before. I have an FXO on router with MGCP config from CUCM. I can call out to outside via this FXO port but cannot get inbound call. I try to set Attendant DN to my phone but it rang only 1 time then it disconnect. Have anyone found it before? Thank. below is log that  I got from debug voip ccapi inout
Voice_Gateway01#debug voip ccapi inout
voip ccapi inout debugging is on
Feb  5 17:44:12.081: //-1/E69C4CFD8158/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=0850666364
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=0   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Feb  5 17:44:12.081: //-1/E69C4CFD8158/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x23117590, Call Info(
   Calling Number=0850666364,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening
=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFl
ag=TRUE,
   Incoming Dial-peer=99903099, Progress Indication=ORIGINATING SIDE IS NON ISDN
(3), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALS
E), Call Id=-1
Feb  5 17:44:12.081: //-1/E69C4CFD8158/CCAPI/ccCheckClipClir:
   In: Calling Number=0850666364(TON=Unknown, NPI=Unknown, Screening=Not Screene
   Out: Calling Number=0850666364(TON=Unknown, NPI=Unknown, Screening=Not Screen
Feb  5 17:44:12.081: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Feb  5 17:44:12.081: :cc_get_feature_vsa malloc success
Feb  5 17:44:12.081:  cc_get_feature_vsa count is 1
Feb  5 17:44:12.081: :FEATURE_VSA attributes are: feature_name:0,feature_time:97
2239528,feature_id:82224
Feb  5 17:44:12.081: //82224/E69C4CFD8158/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=0850666364(TON=Unknown, NPI=Unknown, Screening=Not S
   Called Number=(TON=Unknown, NPI=Unknown))
Feb  5 17:44:12.085: //82224/E69C4CFD8158/CCAPI/cc_process_call_setup_ind:
   Event=0x3EC70950
   >>>>CCAPI handed cid 82224 with tag 99903099 to app "MGCPAPP"
Feb  5 17:44:12.085: //82224/E69C4CFD8158/CCAPI/ccCallSetContext:
   Context=0x3A04A6E0
Feb  5 17:44:12.085: //82224/E69C4CFD8158/CCAPI/ccCallSetupAck:
   Call Id=82224
Feb  5 17:44:12.085: //82224/E69C4CFD8158/CCAPI/cc_api_set_transfer_info:
   Transfer Number=, Transfer Reason=0x0
Feb  5 17:44:12.085: //82224/E69C4CFD8158/CCAPI/ccCallConnect:
   Progress Indication=NULL(0), Data Bitmask=0x0
   Call Entry(Connected=TRUE, Responsed=TRUE)
Feb  5 17:44:12.089: //82224/E69C4CFD8158/CCAPI/ccCallModify:
   Nominator=0x1, Params=0x3F2CAA60, Call Id=82224
Feb  5 17:44:12.089: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x3EAB8900, Interface Type=9, Destination=0.0.0.0, Mode=0x9,
   Call Params(Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screeni
ng=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=, FinalDestinationFlag=FALSE, Outgoing Dial-peer=0, Call
Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Appl
ication Call Id=)
Feb  5 17:44:12.089: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Feb  5 17:44:12.089: :cc_get_feature_vsa malloc success
Feb  5 17:44:12.089:  cc_get_feature_vsa count is 2
Feb  5 17:44:12.089: :FEATURE_VSA attributes are: feature_name:0,feature_time:97
2250056,feature_id:82225
Feb  5 17:44:12.089: //82225/E69C4CFD8158/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=9, FlowMode=1
Feb  5 17:44:12.089: //82225/E69C4CFD8158/CCAPI/ccCallSetContext:
   Context=0x3A04A4D0
Feb  5 17:44:12.093: //82224/E69C4CFD8158/CCAPI/cc_api_call_modify_done:
   Result=0, Interface=0x23117590, Call Id=82224
Feb  5 17:44:12.093: //82225/E69C4CFD8158/CCAPI/cc_api_call_connected:
   Interface=0x3EAB8900, Data Bitmask=0x0, Progress Indication=NULL(0),
   Connection Handle=0
   Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Feb  5 17:44:12.093: //82225/E69C4CFD8158/CCAPI/ccConferenceCreate:
   (confID=0xFFFFFFFF, callID1=0x14131, gcid=0-0-0-0, tag=0x0)
Feb  5 17:44:12.093: //82224/E69C4CFD8158/CCAPI/ccConferenceCreate:
   (confID=0xFFFFFFFF, callID2=0x14130, gcid=E69C4CFD-CB6611E5-8158F33D-A05EE185
, tag=0x0)
   Conference Id=0xFFFFFFFF, Call Id1=82225, Call Id2=82224, Tag=0x0
Feb  5 17:44:12.093: //82225/xxxxxxxxxxxx/CCAPI/cc_api_ha_call_active_notify:
Feb  5 17:44:12.093: call_info mainst_callID:0x14131, peer_callID:0x14130, confI
D:0xA097, spi_type:6, media_flo_thru:1,num_streams:1, swmtpmsp_present:0
Feb  5 17:44:12.093:   stream[0]: callid:0x14131, media_passthrough:0
Feb  5 17:44:12.093: //82225/E69C4CFD8158/CCAPI/cc_api_bridge_done:
   Conference Id=0xA097, Source Interface=0x3EAB8900, Source Call Id=82225,
   Destination Call Id=82224, Disposition=0x0, Tag=0x0
Feb  5 17:44:12.093: //82224/E69C4CFD8158/CCAPI/cc_api_bridge_done:
   Conference Id=0xA097, Source Interface=0x23117590, Source Call Id=82224,
   Destination Call Id=82225, Disposition=0x0, Tag=0xFFFFFFFF
Feb  5 17:44:12.093: //82225/E69C4CFD8158/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0xA097, Destination Call Id=82224)
   Call Entry(Conference Id=0xA097, Destination Call Id=82225)
Feb  5 17:44:12.093: confID:0xA097; callEntry1 callID1:0x14131, type:9; callEntr
y2 callID2:0x14130, type:6
Feb  5 17:44:12.093: //82224/E69C4CFD8158/CCAPI/cc_api_caps_ind:
   Destination Interface=0x3EAB8900, Destination Call Id=82225, Source Call Id=8
2224,
   Caps(Codec=0x1, Fax Rate=0x1, Fax Version:=0, Vad=0x1,
   Modem=0x2, Codec Bytes=20, Signal Type=3)
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
Feb  5 17:44:12.093: //82225/E69C4CFD8158/CCAPI/cc_api_caps_ind:
   Destination Interface=0x23117590, Destination Call Id=82224, Source Call Id=8
2225,
   Modem=0x2, Codec Bytes=160, Signal Type=2)
Feb  5 17:44:12.093: //82225/E69C4CFD8158/CCAPI/cc_api_caps_ack:
2225,
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_NONE(0x1), Fax Version:=0, Vad=OF
F(0x1),
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=1756)
Feb  5 17:44:12.093: //82224/E69C4CFD8158/CCAPI/cc_api_caps_ack:
2224,
F(0x1),
Feb  5 17:44:12.093: //82225/E69C4CFD8158/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0xA097, Call Id1=82225, Call Id2=82224
Feb  5 17:44:12.093: //82224/E69C4CFD8158/CCAPI/cc_api_voice_mode_event:
   Call Id=82224
   Call Entry(Context=0x3A04A6E0)
Feb  5 17:44:12.097: //82224/E69C4CFD8158/CCAPI/ccSetDigitTimeouts:
   Initial Digit Timeout=4000(ms), Inter Digit Timeout=4000(ms)
   Call Entry(Inter Digit Timeout=4000(ms), Initial Digit Timeout=4000(ms))
Feb  5 17:44:12.097: //82224/E69C4CFD8158/CCAPI/ccRestartDigitTimeoutMsec:
   Digit Timeout=0, Call Id=82224
Feb  5 17:44:12.097: //82224/E69C4CFD8158/CCAPI/ccCallReportDigits:
   (callID=0x14130, digit_event=0x1, enable=TRUE, consume=FALSE)
   Enabled=TRUE, Call Id=82224
Feb  5 17:44:12.097: //82224/E69C4CFD8158/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x23117590, callID=0x14130, disp=0, digit_event=0x1, enable=TRUE, con
sume=FALSE)
   Enabled=TRUE, Disposition=0x0, Interface=0x23117590, Call Id=82224
   Call Entry(Initial Digit Timeout=4000(ms), Inter Digit Timeout=4000(ms))
Feb  5 17:44:12.097: //82224/E69C4CFD8158/CCAPI/ccCallModify:
   Nominator=0x1000, Params=0x3F2CA240, Call Id=82224
Feb  5 17:44:12.097: //82224/E69C4CFD8158/CCAPI/cc_api_call_modify_done:
HM_Voice_Gateway01#Result=0, Interface=0x23117590, Call Id=82224
Feb  5 17:44:12.097: //82224/E69C4CFD8158/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Ring Back,
   Tone Direction=Network, Params=0x0, Call Id=82224
Feb  5 17:44:12.925: //82224/E69C4CFD8158/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x23117590, Call Id=82224
   Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Feb  5 17:44:12.925: //82224/E69C4CFD8158/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Null,
Feb  5 17:44:12.925: //82224/E69C4CFD8158/CCAPI/ccCallReportDigits:
   (callID=0x14130, digit_event=0x0, enable=FALSE, consume=FALSE)
Feb  5 17:44:12.925: //82224/E69C4CFD8158/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x23117590, callID=0x14130, disp=0, digit_event=0x0, enable=FALSE, co
nsume=FALSE)
Feb  5 17:44:12.925: //82225/E69C4CFD8158/CCAPI/ccGetCallStatistics:
   Call Stats=0x3F35FF70, Call Id=82225
Feb  5 17:44:12.925: //82225/E69C4CFD8158/CCAPI/ccConferenceDestroy:
   Conference Id=0xA097, Tag=0x0
Feb  5 17:44:12.925: confID:0xA097; callEntry1 callID1:0x14131, type:9; callEntr
Feb  5 17:44:12.925: //82225/E69C4CFD8158/CCAPI/cc_api_bridge_drop_done:
Feb  5 17:44:12.925: //82224/E69C4CFD8158/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=82225, Disposition=0x0, Tag=0x0
Feb  5 17:44:12.925: //82225/E69C4CFD8158/CCAPI/cc_generic_bridge_done:
Feb  5 17:44:12.925: //82224/E69C4CFD8158/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect C
ause=16)
Feb  5 17:44:12.929: //82224/E69C4CFD8158/CCAPI/ccCallDisconnect:
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Feb  5 17:44:12.929: //82224/E69C4CFD8158/CCAPI/cc_api_get_transfer_info:
   Transfer Number=NULL
Feb  5 17:44:12.929: //82225/E69C4CFD8158/CCAPI/ccCallDisconnect:
ause=0)
Feb  5 17:44:12.937: //82225/E69C4CFD8158/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x3EAB8900, Tag=0x0, Call Id=82225,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Feb  5 17:44:12.937: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Feb  5 17:44:12.937: :cc_free_feature_vsa freeing 39F35BC0
Feb  5 17:44:12.937:  vsacount in free is 1
Feb  5 17:44:12.957: //82224/E69C4CFD8158/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x23117590, Tag=0x0, Call Id=82224,
HM_Voice_Gateway01#
Feb  5 17:44:12.957: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Feb  5 17:44:12.957: :cc_free_feature_vsa freeing 39F332A0
Feb  5 17:44:12.957:  vsacount in free is 0
7 Replies 7
saif musa
Level 4
Level 4
Could you upload router running-config please, the above debug shows the call is disconnected with cause (16) which normal call clearing.
Voice_Gateway01#sh run
Building configuration...
Current configuration : 4506 bytes
! Last configuration change at 01:14:56 BKK Sat Feb 6 2016
! NVRAM config last updated at 01:14:57 BKK Sat Feb 6 2016
version 15.4
service timestamps log datetime localtime show-timezone
service password-encryption
hostname Voice_Gateway01
boot-start-marker
boot-end-marker
card type e1 0 0
card type e1 0 1
logging buffered 128000
enable secret 5 $1$VzC5$.BMCjcVdW2thjnfJuOoyM1
no aaa new-model
clock timezone BKK 7 0
network-clock-participate wic 0
network-clock-participate wic 1
network-clock-select 1 E1 0/0/0
network-clock-select 2 E1 0/1/0
no ip domain lookup
ip cef
no ipv6 cef
isdn switch-type primary-4ess
cts logging verbose
voice-card 0
license udi pid CISCO2911/K9 sn FGL194110T5
hw-module pvdm 0/0
hw-module pvdm 0/1
username administrator password 7 02320C7B
redundancy
controller E1 0/0/0
 pri-group timeslots 1-31 service mgcp
controller E1 0/1/0
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 ip address 10.10.221.10 255.255.255.0
 duplex auto
 speed auto
interface GigabitEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
interface GigabitEthernet0/2
 no ip address
 shutdown
 duplex auto
 speed auto
interface Serial0/0/0:15
 no ip address
 encapsulation hdlc
 isdn switch-type primary-qsig
 isdn timer T310 120000
 isdn protocol-emulate network
 isdn incoming-voice voice
 isdn bind-l3 ccm-manager
 no cdp enable
interface Serial0/1/0:15
 no ip address
 encapsulation hdlc
 isdn switch-type primary-net5
 no cdp enable
ip default-gateway 10.10.221.254
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 10.10.221.254
control-plane
voice-port 0/0/0:15
voice-port 0/1/0:15
voice-port 0/2/0
 timing hookflash-out 50
 timing guard-out 1000
 caller-id enable
voice-port 0/2/1
 caller-id enable
voice-port 0/2/2
voice-port 0/2/3
voice-port 0/3/0
 caller-id enable
voice-port 0/3/1
voice-port 0/3/2
voice-port 0/3/3
mgcp
mgcp call-agent 10.10.221.4 2427 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
ccm-manager music-on-hold
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager config server 10.10.221.4
ccm-manager config
dial-peer voice 99902990 pots
 service mgcpapp
 port 0/2/0
dial-peer voice 99902991 pots
 service mgcpapp
 port 0/2/1
dial-peer voice 99903990 pots
 service mgcpapp
 port 0/3/0
dial-peer voice 99903991 pots
 service mgcpapp
 port 0/3/1
dial-peer voice 99902099 pots
 service mgcpapp
 port 0/2/0
dial-peer voice 99902199 pots
 service mgcpapp
 port 0/2/1
dial-peer voice 99902299 pots
 service mgcpapp
 port 0/2/2
dial-peer voice 99902399 pots
 service mgcpapp
 port 0/2/3
dial-peer voice 99903099 pots
 service mgcpapp
 port 0/3/0
dial-peer voice 99903199 pots
 service mgcpapp
 port 0/3/1
dial-peer voice 99903299 pots
 service mgcpapp
 port 0/3/2
dial-peer voice 99903399 pots
 service mgcpapp
 port 0/3/3
gatekeeper
 shutdown
line con 0
 logging synchronous
 login local
 transport preferred telnet
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 logging synchronous
 login local
 transport input telnet
scheduler allocate 20000 1000
ntp master 1
ntp server 10.1.1.222
end
How did your FXO port configure inside your call-manager ? port direction set to both or outgoing  ( default is both ) ?
If its set to (both) then try to change battery polarity reversal configuration under your FXO voice ports to ( no battery-reversal )
Hope thats help
Update the config to SIP/H323 and use the connection plar command with the appropriate dial-peers.
Jason
thank you very match, that helped me, i was having the same issue and your solution helped me.
thanks again.
Spoiler
Good luck
In your FXO voice port config, have you tried adding connection plar statement?
voice-port 0/2/X
 coneection plar opx <extension>
 caller-id enable
-Deven Gandhi
*Please rate all useful post
