FXO outgoing calls pass through problem
VKMH
HI,
I have CME 2921 router .8 FXO PSTN line comming to my router  outgoing calls pass through only  FXO port 0/0/0 .  but incomming call comming with all FXO  port.
show my running configuration
CME#show running-config
Building configuration...
Current configuration : 28241 bytes
! Last configuration change at 14:21:20 UTC Sat May 18 2013 by admin
version 15.3
hostname CME
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret 4 X4ZqtPJ///KxuEWxHSsJrv3beQVnz2ise/xj8fF6eFU
no aaa new-model
clock timezone UTC 3 0
ip cef
ip dhcp pool 1
network 192.168.10.0 255.255.255.0
default-router 192.168.10.1
option 150 ip 192.168.10.1
no ip domain lookup
ip domain name yourdomain.com
no ipv6 cef
trunk group fxo
voice-class cause-code 1
hunt-scheme longest-idle
trunk group FXO
crypto pki trustpoint TP-self-signed-1480474283
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1480474283
revocation-check none
rsakeypair TP-self-signed-1480474283
crypto pki certificate chain TP-self-signed-1480474283
certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31343830 34373432 3833301E 170D3132 30383037 31303231
  30305A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 34383034
  37343238 3330819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100CE31 54464708 8BC3C22D 347D958E 3AE36BBC 16C56FA2 BD8290E5 D732A779
  FA3EFE94 CB157EA8 2F6BB3AB 7993733A 5F74188B 46D1420C FF20223D 33807E92
  667FE112 C93EF28F 60F4695D 821128CD 82A4B33E 53F15888 BC2B16E3 3CAB0B31
  6DEF8109 882CC001 E5098472 721ABAE2 D2A458E7 E16716AA C3D5723D 38E55222
  62170203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 1477083B A9425D93 CCEB3715 1B69E262 F618B88E 16301D06
  03551D0E 04160414 77083BA9 425D93CC EB37151B 69E262F6 18B88E16 300D0609
  2A864886 F70D0101 05050003 8181007D 071BDAD1 7A89C0D2 54382FCB 74881C0E
  524784C5 972E41CA 0CF827D4 8523F08D EDB74400 FD493D5D 6EDE52B2 A8D68A09
  20490C72 C9B21662 770B5B94 0B96A360 B83B20E7 5295A1AF C0A44518 0B022122
  A666CBBF B803B8CD CB183A28 4E261E71 823DCF69 D185892E 57DA8B3A BE22EDA5
  E7CA8354 9504B0F0 A8AE5F16 0D6329
        quit
voice-card 0
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
sip
  registrar server expires max 300 min 60
voice class codec 1
codec preference 1 g711ulaw
voice class custom-cptone STC
dualtone disconnect
  frequency 425
  cadence 250 250
voice register global
mode cme
source-address 192.168.10.1 port 5060
max-dn 40
max-pool 20
load 8961 sip8961.9-2-2SR1-9.loads
authenticate register
authenticate realm all
timezone 31
mwi reg-e164
voicemail 999
tftp-path flash:
create profile sync 0005461448220091
camera
video
voice register dn  1
number 252
call-forward b2bua noan 100 timeout 20
allow watch
name Operator
label Operator
voice register pool  1
id mac 1CAA.0710.0AC1
type 8961 addon 1 CKEM
number 1 dn 1
dtmf-relay rtp-nte sip-kpml sip-notify
username cisco password cisco
codec g711ulaw
no vad
camera
video
blf-speed-dial 1 242 label "Mr.Mohd_Al_Hathlol_(GM)"
blf-speed-dial 2 222 label "Mr.Abdul_Aziz_Al_Oraini"
blf-speed-dial 3 231 label "Mr.Dr.Kamal"
blf-speed-dial 4 246 label "Mr.Farouk_Ali_Osman"
blf-speed-dial 5 254 label "Mr.Hamdan"
blf-speed-dial 6 221 label "Mr.Yousuf_Mohd"
blf-speed-dial 7 223 label "Mr.Shakir_Mohd"
blf-speed-dial 8 225 label "Mr.Abdulrahman"
blf-speed-dial 9 226 label "Mr.Khaja"
blf-speed-dial 10 227 label "Mr.Abdulhakim"
blf-speed-dial 11 262 label "Mr.Gethru"
blf-speed-dial 12 229 label "Mr.Fadi"
blf-speed-dial 13 232 label "Mr.Joy"
blf-speed-dial 14 233 label "Mr.Sadik_Ali"
blf-speed-dial 15 234 label "Mr.Alieid"
blf-speed-dial 16 235 label "Mr.Shakir"
blf-speed-dial 17 236 label "Mr.Ahmad_Dugeimat"
blf-speed-dial 18 237 label "Mr.Sameh_Kharmouti"
blf-speed-dial 19 240 label "Mr.Mathew"
blf-speed-dial 20 241 label "Mr.Sagar"
blf-speed-dial 21 243 label "Mr.Federico_Lumibao"
blf-speed-dial 22 244 label "Conference_Room"
blf-speed-dial 23 245 label "Mr.Abdil_Ganny"
blf-speed-dial 24 247 label "Mr.Mohannad_Attala"
blf-speed-dial 25 248 label "Mr.Faisal_Al_Hathilol"
blf-speed-dial 26 249 label "Mr.Abdullah_Hassan_TV"
blf-speed-dial 27 250 label "Production_Foreman_2"
blf-speed-dial 28 251 label "Mr.Abdullah_Nasruddin"
blf-speed-dial 29 253 label "Mr.Baha_Awad"
blf-speed-dial 30 255 label "Gate_H.O"
blf-speed-dial 31 256 label "Mr.Alan_Villavicencio_2(Reser)"
blf-speed-dial 32 257 label "Mr.Mohd_Habani"
blf-speed-dial 33 258 label "Mr.Sultan"
blf-speed-dial 34 260 label "Clinic"
blf-speed-dial 35 228 label "Mr.Raymond"
blf-speed-dial 36 263 label "Main_Gate"
blf-speed-dial 37 264 label "Production_Foreman_1"
blf-speed-dial 38 265 label "GM-Serpo"
blf-speed-dial 39 266 label "Mr.Nabeel"
blf-speed-dial 40 267 label "GM-Guest"
blf-speed-dial 41 268 label "Mr.Ibrahim_Yassin"
blf-speed-dial 42 269 label "Office_Boy"
blf-speed-dial 43 270 label "Mr.Ali_Abdulhafiz"
blf-speed-dial 44 271 label "Mr.Perwez_Akhtar"
blf-speed-dial 45 272 label "Mr.Ronald_Muncal"
blf-speed-dial 46 273 label "Mr.Alan_Villavicencio"
blf-speed-dial 47 274 label "Conference_RM(GM)"
blf-speed-dial 48 277 label "Sales_Secretary_2"
blf-speed-dial 49 278 label "Prod_Foreman"
blf-speed-dial 50 280 label "Serpo_Stores"
blf-speed-dial 51 284 label "Mr.Jahangir"
license udi pid CISCO2921/K9 sn FCZ163270CP
hw-module ism 0
hw-module pvdm 0/0
file privilege 0
username admin privilege 15 password 0 admin
redundancy
interface Loopback0
ip address 172.16.1.1 255.255.255.0
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address 192.168.10.1 255.255.255.0
duplex auto
speed auto
interface ISM0/0
ip unnumbered Loopback0
service-module ip address 172.16.1.2 255.255.255.0
!Application: CUE Running on ISM
service-module ip default-gateway 172.16.1.1
interface GigabitEthernet0/1
ip address 192.168.1.159 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface ISM0/1
description Internal switch interface connected to Internal Service Module
no ip address
interface Vlan1
no ip address
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash:/GUI
ip route 172.16.1.2 255.255.255.255 ISM0/0
tftp-server flash:sip8961.9-2-2SR1-9.loads
tftp-server flash:xml-test.html
tftp-server flash:home.shtml
tftp-server flash://172.16.1.1/ccme.html
tftp-server html
tftp-server flash://192.168.10.1/ccme.html
tftp-server flash:/GUI
control-plane
voice-port 0/0/0
trunk-group FXO
supervisory disconnect dualtone mid-call
supervisory custom-cptone STC
input gain 14
timeouts initial 0
timeouts interdigit 2
timeouts call-disconnect 3
timeouts ringing 5
timeouts wait-release 3
connection plar 888
caller-id enable
voice-port 0/0/1
trunk-group FXO
input gain 14
timeouts initial 0
timeouts ringing 5
connection plar 888
caller-id enable
voice-port 0/0/2
trunk-group FXO
input gain 14
timeouts initial 0
timeouts ringing 5
connection plar 888
caller-id enable
voice-port 0/0/3
trunk-group FXO
input gain 14
timeouts initial 0
timeouts ringing 5
connection plar 888
caller-id enable
voice-port 0/1/0
trunk-group FXO
input gain 14
timeouts initial 0
timeouts ringing 5
connection plar 888
caller-id enable
voice-port 0/1/1
trunk-group FXO
input gain 14
timeouts initial 0
timeouts ringing 5
connection plar 888
caller-id enable
voice-port 0/1/2
trunk-group FXO
input gain 14
timeouts initial 0
timeouts ringing 5
connection plar 888
caller-id enable
voice-port 0/1/3
trunk-group FXO
input gain 14
timeouts initial 0
timeouts ringing 5
connection plar 888
caller-id enable
voice-port 0/2/0
trunk-group FXO
input gain 14
timeouts initial 0
timeouts ringing 5
connection plar 888
caller-id enable
voice-port 0/2/1
trunk-group FXO
input gain 14
timeouts initial 0
timeouts ringing 5
connection plar 888
caller-id enable
voice-port 0/2/2
trunk-group FXO
input gain 14
timeouts initial 0
timeouts ringing 5
connection plar 888
caller-id enable
voice-port 0/2/3
trunk-group FXO
input gain 14
timeouts initial 0
timeouts ringing 5
connection plar 888
caller-id enable
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
dial-peer cor custom
name internal
name local
name national
name mobile
name international
dial-peer cor list internal
member internal
dial-peer cor list local
member local
dial-peer cor list national
member national
dial-peer cor list mobile
member mobile
dial-peer cor list international
member international
dial-peer cor list Restricted
member internal
dial-peer cor list LocalCalls
member internal
member local
dial-peer cor list LongDistance
member internal
member local
member national
member mobile
dial-peer cor list International
member internal
member local
member national
member mobile
dial-peer voice 666 voip
description " Dial-Peer for CUE VM "
destination-pattern 999
session protocol sipv2
session target ipv4:172.16.1.2
dtmf-relay h245-alphanumeric h245-signal rtp-nte sip-notify
codec g711ulaw
no vad
dial-peer voice 101 voip
description " Dial-Peer for CUE AA"
destination-pattern 888
codec g711ulaw
no vad
dial-peer voice 1 pots
trunkgroup FXO
corlist outgoing local
destination-pattern 9[19]..
forward-digits 3
dial-peer voice 2 pots
trunkgroup FXO
destination-pattern 9[2-8][0-9][1-9]....
forward-digits 7
dial-peer voice 3 pots
trunkgroup FXO
corlist outgoing mobile
destination-pattern 905[056].......
prefix 05
dial-peer voice 4 pots
trunkgroup FXO
corlist outgoing national
destination-pattern 90[234679].......
prefix 0
dial-peer voice 5 pots
trunkgroup FXO
corlist outgoing international
destination-pattern 900T
prefix 00
dial-peer voice 6 pots
trunkgroup FXO
destination-pattern 9600T
prefix 600
dial-peer voice 7 pots
trunkgroup FXO
destination-pattern 9800T
prefix 800
presence
presence call-list
sip-ua
presence enable
gatekeeper
shutdown
telephony-service
conference hardware
conference transfer-pattern
video
no auto-reg-ephone
max-ephones 100
max-dn 250
ip source-address 192.168.10.1 port 2000
system message LCC_SIPOREX
time-zone 31
date-format dd-mm-yy
voicemail 999
mwi reg-e164
max-conferences 8 gain -6
web admin system name admin secret 5 $1$qHe3$xblvRD1ouV4jr8RcGUiMM.
dn-webedit
time-webedit
transfer-system full-consult
create cnf-files version-stamp 7960 May 05 2013 16:13:52
ephone-dn  1
number 221
description Mr.Yousuf Mohd
name Mr.Yousuf Mohd
call-forward busy 999
call-forward noan 999 timeout 15
corlist incoming LocalCalls
ephone-dn  2
number 222
description Mr.Abdul Aziz Al Oraini
name Mr.Abdul Aziz Al Oraini
call-forward noan 999 timeout 10
ephone-dn  3
number 223
description Mr.Shakir.Mohd
name Mr.Shakir.Mohd
ephone-dn  5
number 225
description Mr.Abdulrahman
name Mr.Abdulrahman
call-forward all 262
corlist incoming Restricted
Please add the output of "show dial-peer voice summary" and "debug voice dialpeer" during aoutgoing call.
Regards.
