FXO Plar
Leonardo Santana
I have an 2921 with VIC2-4FXO for incoming calls, i configure an PLAR, but i cannot receive calls.
I enabled the debug vpm signal and i receive this message:
Feb 17 12:35:35.424: fxols_line_reversal_clid_wait. On_hook line reversal detected possibily due to crossed cable
Feb 17 12:35:46.448: fxols_line_reversal_clid_wait. On_hook line reversal detected possibily due to crossed cable
Feb 17 12:35:50.484: fxols_line_reversal_clid_wait. On_hook line reversal detected possibily due to crossed cable
What could be?
Leonardo Santana
Leonardo Santana
*** Rate All Helpful Responses***
islam.kamal
Level 10
Level 10
Dear
1-Please confirm this was not a crossed cable or a flip in tip and ring leads, and cables were inspected and no physical layer changes .
2-Please confirm the issue was not related to the FXO card (errors were only related to one card). To check swap the FXO  card position in the router.
Running "
show voice dsp group all
Please confirm  the DSPs were up and looked normal. Reset the DSP and test again. If your configuration is true , i hink 100% the problem will be from the telecom central ( may be in the devices in the teleco central which you get the service from it.
Thank you
please rate if this will help
paolo bevilacqua
try
no battery-reversal
mohamed helmy
Hello Leonardo,
Can you please give a sample for the configuration under the voice-port?
Mohamed Helmy
Regards, Mohamed Helmy
islam.kamal
Level 10
Level 10
Dear
Running "
Thank you
Thanks everyone for the help
The problem was the crossed cable, i change the cable and its working.
Thanks again
Leonardo Santana
Leonardo Santana
