FXS Port on CME 7
Scott Hanson
Level 3
Level 3
                   Hey,
running FXS ports on CME 7 and I am trying to configure a Fax machine to hang off the FXS port.  I keep getting a busying signal when calling in bound.  the translation is for DN 109
voice translation-rule 1
     rule 1 /8866/ /700/
     rule 2 /8183/ /401/
     rule 3 /8896/ /896/
      rule 4 /8109/ /109/
Then I have
voice translation-profile TranslateDID translate called 1
Then on the voice-port I have
voice-port 0/0/0
     signal groundStart
     connection plar 109
Can someone take a look and see what I might be missing?
Replies rated!
paolo bevilacqua
Should be singal loopstart, and no connection plar.
You will need a dial-peer pots to send calls to 109 to the port.
Or eliminate the translation rule and send calls what whatever number is received by telco.
Thanks Paolo,
Here is my dial-peer but I am still getting a buy signal
dial-peer voice 10 pots
     translation-profile incoming TranslateDID
     translation-profile outgoing profile1
     destination-pattern 109
     incoming called-number 109
     fax rate voice
     direct-inward-dial 109
I'm afraid you have some confusion here and there, seems like you weren't sure how it should be done so there is a lot of 109s around.
Jorge Armijo
Level 4
Level 4
Hi!
You just need:
Dial-peer 109 pots
Destination-pattern 109
Port 0/0/0
Voice-port 0/0/0
Signal loop
Any other digit manipulation is to make the line reachable from PSTN.
Jorge Armijo
Sent from Cisco Technical Support Android App
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
