10-02-2012 07:55 AM - edited 03-16-2019 01:28 PM
Hey,
running FXS ports on CME 7 and I am trying to configure a Fax machine to hang off the FXS port. I keep getting a busying signal when calling in bound. the translation is for DN 109
voice translation-rule 1
rule 1 /8866/ /700/
rule 2 /8183/ /401/
rule 3 /8896/ /896/
rule 4 /8109/ /109/
Then I have
voice translation-profile TranslateDID translate called 1
Then on the voice-port I have
voice-port 0/0/0
signal groundStart
connection plar 109
Can someone take a look and see what I might be missing?
Replies rated!
10-02-2012 07:58 AM
Should be singal loopstart, and no connection plar.
You will need a dial-peer pots to send calls to 109 to the port.
Or eliminate the translation rule and send calls what whatever number is received by telco.
10-02-2012 08:33 AM
Thanks Paolo,
Here is my dial-peer but I am still getting a buy signal
dial-peer voice 10 pots
translation-profile incoming TranslateDID
translation-profile outgoing profile1
destination-pattern 109
incoming called-number 109
fax rate voice
direct-inward-dial 109
10-02-2012 08:58 AM
I'm afraid you have some confusion here and there, seems like you weren't sure how it should be done so there is a lot of 109s around.
10-02-2012 07:01 PM
Hi!
You just need:
Dial-peer 109 pots
Destination-pattern 109
Port 0/0/0
Voice-port 0/0/0
Signal loop
Any other digit manipulation is to make the line reachable from PSTN.
Jorge Armijo
Sent from Cisco Technical Support Android App
