06-18-2012 11:54 PM - edited 03-16-2019 11:44 AM
I need some assistance on setting up some FXS Ports.
I have zero experience with H.323 configuration as I've always had my gateways managed my MGCP.
What the customer is looking for is for a number of FXS ports to be configured with outbound dial-tone by pressing 9 and having the ability to make phone calls. It's for a postal machine and doesn't require inbound dialing, only outbound.
I've attached the config of the device, any assistance on this would be awesome.
Thanks!
Solved! Go to Solution.
06-19-2012 06:22 AM
H.323 is only really needed if you're going to route the calls toward CUCM. If the gateway has both the FXS ports and the PSTN-facing ports in it you can accomplish it with just dial-peers. Here are the two docs to get you going for H.323:
Cisco IOS H.323 Configuration Guide
Cisco IOS H.323 Configuration for Use with Cisco CallManager
06-19-2012 06:22 AM
06-19-2012 12:33 PM
Thanks Jonathan!
I'll check those out.
