Gateway Call Logs
markpexa1
I'm trying to find a fax machine that is dialing a phone number by mistake.  Apparently the fax machine is masked with our main number.  I tried issuing a show log | begin Feb 5 06 on the gateway, however it's not returning any results.  The same command in Jan returns results.  Any tips on finding the DN that is dialing a number by mistake?
paolo bevilacqua
Start mentioning system and version you're using.
My apologies.  CUCM 8.6.2
