GDM MWI across CUCME sites
dkilpatrick1
I've got a tricky problem which is a little difficult to solve.
The setup:
 SITE 1                          SITE 2
  C2821    ----    WAN    ----    C2821
CUCME 8.6                       CUCME 8.6
CUE 7.0.5
Site 1 is running CUCME8.6 on a 2821, plus AIM-CUE for VoiceMail.
Site 2 is running CUCME8.6 on a 2821.
SIP trunk between both sites.
There are 4 extensions at each site (with mailboxes), and there is a GDM setup for each site.
I am having difficulty finding a suitable configuration to enable MWI to function for the GDM at site 2.
If I use unsolicited SIP MWI notification, only one gateway IP address can be set in CUE (for either Site 1, or Site 2) for unsolicited MWI delivery.
If I use SIP subscribe MWI notification, both sites can subscribe successfully to CUE to receive MWI for user mailboxes, however when I try to subscribe the GDM I receive a SIP404 error message (presumably because there is no "user" for the GDM, only a group with associated extension).
Does anyone see a possible way for the GDM extension at site 2 to receive MWI successfully?
Appreciate any suggestions and thoughts.
Jitender Bhandari
see if below helps
http://mickvaites.com/2009/06/installing-two-site-cme-and-a-single-cue/
(Rate if it helps)
JB
Jitender Bhandari
see if below helps
(Rate if it helps)
JB
Thanks .. that solution worked perfectly.
Happy to help,
thanks for updating the post.
JB
