H.323 and partial E1
dszymkowicz
Is it possible to configure E1 on H.323 GW to use for example all 30 channels for incoming calls and 25 for outgoing?
regards
7 Replies 7
acampbell
Yes you can select some timeslots for OUTGOING.
You need to use trunk groups
Something like this
trunk group OUTGOING
controller E1 0/0/0
pri-group timeslots 1-31
trunk-group OUTGOING timeslots 21-31
dial-peer voice 9 pots
trunkgroup OUTGOING
tone ringback alert-no-PI
description *** O/G LEVEL 9 TRAFFIC TO PSTN ***
destination-pattern 9T
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
incoming called-number .
direct-inward-dial
Alex
Regards, Alex. Please rate useful posts.
For now  I cannot test it. Is it possible to limit also incoming calls the same way?
Is it depended from channel selection order (which is configured on provider side)?
Sorry you can not control the INCOMING.
This is controlled by your PRI service provider.
Alex
Thanks a lot for help.
Alex,
I have a similar requirement but I do not see an option to add trunk-group under controller. Did you ever test it, did it work?  Any other suggestions?
Chris
Chris,
Yes this works for me.
PM message sent to you.
Check your inbox
Alex.
Thanks Alex, my issue was that the trunk group was already assigned to serial interface, as soon as I removed it from serial it was available under controller.
Chris
