10-12-2011 04:24 AM - edited 03-16-2019 07:27 AM
Is it possible to configure E1 on H.323 GW to use for example all 30 channels for incoming calls and 25 for outgoing?
regards
10-12-2011 04:43 AM
Yes you can select some timeslots for OUTGOING.
You need to use trunk groups
Something like this
trunk group OUTGOING
controller E1 0/0/0
pri-group timeslots 1-31
trunk-group OUTGOING timeslots 21-31
dial-peer voice 9 pots
trunkgroup OUTGOING
tone ringback alert-no-PI
description *** O/G LEVEL 9 TRAFFIC TO PSTN ***
destination-pattern 9T
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
incoming called-number .
direct-inward-dial
Alex
10-12-2011 05:48 AM
For now I cannot test it. Is it possible to limit also incoming calls the same way?
Is it depended from channel selection order (which is configured on provider side)?
10-12-2011 05:51 AM
Sorry you can not control the INCOMING.
This is controlled by your PRI service provider.
Alex
10-12-2011 05:54 AM
Thanks a lot for help.
06-01-2012 08:58 AM
Alex,
I have a similar requirement but I do not see an option to add trunk-group under controller. Did you ever test it, did it work? Any other suggestions?
Chris
06-04-2012 01:54 AM
Chris,
Yes this works for me.
PM message sent to you.
Check your inbox
Alex.
Please rate useful posts.
06-04-2012 06:09 AM
Thanks Alex, my issue was that the trunk group was already assigned to serial interface, as soon as I removed it from serial it was available under controller.
Chris
