H.323 Gateway config for FXS
wmelick
Beginner
Beginner
I think this is a fairly basic question, but I am trying to send outbound fax calls from an FXS port to a PRI on a Cisco router (configured as H.323).
I have the inbound config OK (assign the FXS voice port an internal station ID, setup an inbound translation rule changing the DID to the station ID, setup a dial peer destination pattern matching the station ID and set it to the  FXS port).
How do I do the inverse to get the FXS port to route out the PRI using an H.323 config?
MOHIT SINGH
Beginner
Beginner
You can just create another POTS dial peer with destination pattern .T and PRI port to send out calls through PRI.
Recognize Your Peers
