H.323 or MGCP
s.loganathan
Hi All,
Which one is more stable in branch office setup with SRST support??
H.323 Gateway or MGCP Gateway.Also let me know the reason..Thanks.
Also let me know which is manageable.
acampbell
MGCP - Centralised configuration of translation etc on the CUCM.
When an MGCP gateway fall back in to SRST it has to invoke a fallback protocol usually H323. You therefore need to configure
ccm fallback and a minimul dial peers etc for SRST.
H323 - You need to configure the dial peers etc locally on the router. Uses its defaault protocol of H323 for SRST.
You need to make a decision.
More config on CUCM  (MGCP)
or More config work on the gateway H323.
MGCP gateway shoew as registered on CUCM due the protocol being client/server.
H323 gateways show as unknown status as this is a PEER to PEER protocol
If you are using partial E1 trunks (IE less than 30 B-Channels on the trunk) to the pstn etc is better practise to use H323
Alex
Regards, Alex. Please rate useful posts.
Payal Bhaduri
There is a document that compares MGCP and H.323 Voice Gateway Protocol
http://www.cisco.com/en/US/tech/tk1077/technologies_tech_note09186a00806fedbe.shtml
MGCP is easier to configure but has limitations because CCM takes all decisions and only works on DNIS.
H323 requires more configuration because of dial-peers but work with ANI, DNIS and redirect number. You have a lot more control.
