10-05-2012 04:42 AM - edited 03-16-2019 01:32 PM
I am encoutering an very strange behaviour.
ECOS - FXS port on FXS112 - SCCP - CUCM cluster - H323 - VoiceRouter - E1 - Provider
We have an ECOS system, which is an emergency system that sends out a message in case of emergency. The system dials internal numbers, national numbers and national mobile numbers, and when the called person answers the call, the system starts to send a voice message on the line.
The ECOS system is connected through several analog lines to FXS ports of an analogue voice gateway. The analogue gateway is connected to the CUCM cluster via SCCP.
The Voice Router that we use to send out the calls, is configured via H323.
The config of my dial-peer is:
dial-peer voice 400 pots
trunkgroup 1
description to BGC
destination-pattern [01]T
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
no digit-strip
For internal calls and national calls, the system works fine.
We have problems when the system dials out to mobile numbers. When the system calls out, it starts to send the message before a call_connect is sent from the provider. So when the called person answers the call, the message is already playing and he misses the beginning of the message.
Calls to mobile numbers are using the same call setup and dial-peer as calls to normal national numbers.
I have tried to send the call over a voice router that uses MGCP, and it works fine then.
I also tried to send the call over a voice dial-peer without the progress indicators, and the problem remains.
For this particular site, we can not configure the Voice Router with MGCP, we have to keep the H323 setup.
Sending out the call over another site, via MGCP, is also not a solution, because if we have problems, the call should be sent over the local external line.
Can anyone help please, I don't know where to start with troubleshooting...
Btw, this emergency system is used for a nuclear power plant, so you can imagine that it is really important. :-)
Thanks a lot!
Antoine
Solved! Go to Solution.
10-05-2012 08:56 AM
Can you check if the device support answer supervsion via battery reversal?
That is the only way so it can know that the call ans been answered remotely, and start media.
10-05-2012 08:56 AM
10-06-2012 06:41 AM
Hello Paolo,
I will check this and let you know.
Thanks for your reply!
Best regards,
Antoine
10-08-2012 05:35 AM
Hi Paolo,
Disabling the battery-reversal solved the problem.
Thanks a lot!
Antoine
