Showing results forĀ
Search instead forĀ
Did you mean:Ā
Hardware Conferencing in CME
bkhanal1971
Level 3
Level 3
Hello:
As far as my understanding goes, hardware conferencing is not an option in CME (ver 8.x in 29xx hardware with PVDM3-64 and one E1 trunk). Is that true? If it is not, could someone post here the configuration steps specific to the hardware conferencing in CME routers?
Thank you.
Hi bkhanal,
The phones are limited to a 3 party conference if you are using the CME software to enable the conferencing. If you need more you can use hardware resoruces. You can follow this amazing guide by Mark H: http://www.markholloway.com/blog/?p=1023
Please rate all useful posts
_____________________________
LinkedIn Profile: do.linkedin.com/in/leosalcie
MDGDP, CCNA, CCNA Voice certified
__________________________________________________
Please remember to rate useful posts clicking on the stars below.
Thank you for the response. Actually I had used the same resource to configure the conferencing resource in my CME. For some reason it didn't work. As soon as i hit confrn button to conference in the 2nd party to the call, both phones give reorder tone. I don't know what went wrong. As soon as I removed "conference hardware" it defaulted to software mode and i could have 3 party conference. However, I am trying to get more than 3 parties in the call. If anybody has any suggestion that would be very much appreciated.
Following are the excerpts of my config
sccp ccm group 1
bind interface GigabitEthernet0/0
associate ccm 1 priority 1
associate profile 1 register MTP1CDF0FB326F0
associate profile 2 register CFB1CDF0FB326F0
keepalive retries 1
keepalive timeout 10
switchover method immediate
switchback method immediate
switchback interval 5
dspfarm profile 1 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 8
associate application SCCP
dspfarm profile 2 conference
codec g729br8
codec g729r8
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
maximum sessions 2
telephony-service
sdspfarm units 5
sdspfarm transcode sessions 48
sdspfarm unregister force
sdspfarm tag 1 MTP1CDF0FB326F0
sdspfarm tag 2 CFB1CDF0FB326F0
conference hardware
Can you post the full config as this is not showing, sccp ccm config, nor ephone-dns configuration for conferencing, you can follow the CME admin guide for step by step directions:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeconf.html#wp1010877
HTH, please rate all useful posts!
Chris
That is weird, like Chris said, post your config.
