02-21-2017 12:15 AM - edited 03-17-2019 09:35 AM
what are the main advatages and dis-advantages of have the VG and CM cluster seperatly other than there being more switches routers in the middle?
02-21-2017 12:24 AM
Hi Ryan,
CUCM and VG dont even care about it, you would have to make sure that you are meeting the bandwidth requirement for the protocol used between them.
(Rate if it helps)
JB
02-21-2017 12:29 AM
thanks for the reply, i thought the same, but customer raised concern about it
02-21-2017 12:34 AM
Check the link below, it has all the explanation you would need.
https://supportforums.cisco.com/document/12142746/understanding-transport-layer-sip-and-h323
(Rate if it helps)
JB
02-21-2017 02:22 AM
https://supportforums.cisco.com/discussion/11249476/delay-between-voice-gateway-and-call-manager
JB
02-21-2017 05:45 AM
I strongly suggest your read Cisco Collaboration SRND where different deployment models are documented and described well.
