06-12-2013 01:43 PM - edited 03-16-2019 05:50 PM
I am a new user to CUCM and am running 9.1.1a.
We have 4 PRI's interfaced into a Cisco Gateway using h.323. When I debug Q931, I see the calling name is being sent by the telco (see below).
Currently on the 7945G we see the calling number displayed but do not see the name. Sorry I am posting this lame question but I could not find the configuration information in the documentation.
Here is a sample of the inbound
Jun 12 20:40:46.444: ISDN Se0/0/0:23 Q931: RX <- SETUP pd = 8 callref = 0x2DB9
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Facility i = 0x9F8B0100A117020101020100800F536569646572204572696320202020
Protocol Profile = Networking Extensions
0xA117020101020100800F536569646572204572696320202020
Component = Invoke component
Invoke Id = 1
Operation = CallingName
Name Presentation Allowed Extended
Name = Seider Eric
Calling Party Number i = 0x2183, '3146056094'
Plan:ISDN, Type:National
Called Party Number i = 0xA1, '3146573325'
Locking Shift to Codeset 6
Codeset 6 IE 0x1 i = '>'
Jun 12 20:40:46.448: ISDN Se0/0/0:23 Q931: Received SETUP callref = 0xADB9 callID = 0x1B5D switch = primary-ni interface = User
Jun 12 20:40:46.448: ISDN Se0/0/0:23 Q931: TX -> CALL_PROC pd = 8 callref = 0xADB9
Jun 12 20:40:46.584: ISDN Se0/0/0:23 Q931: TX -> ALERTING pd = 8 callref = 0xADB9
Solved! Go to Solution.
06-12-2013 01:54 PM
You need "isdn supp-service name calling" under PRi interface.
06-12-2013 02:02 PM
As answered above.
06-12-2013 01:54 PM
06-12-2013 02:01 PM
Thanks, Paolo. To be clear, I need to make this change on the gateway as in the example below?
interface Serial0/1/0:23
description XXXXXXXXXXXXXX
no ip address
encapsulation hdlc
no logging event link-status
no snmp trap link-status
isdn switch-type primary-ni
isdn incoming-voice voice
trunk-group STL-PRI-WINDSTREAM 2
no cdp enable
06-12-2013 02:02 PM
As answered above.
