High Availability for SFTP Servers
I'm looking into a solution for our CUCM\CUC Backup.
Both of them are virtual and in different physical locations but with good bandwidth.
we would have 2 SFTP servers, one in each location, and would sit behind a virtual IP (vIP).
If one sftp is down, the vIP would switch to the other one.
 the backups would replicate between sftp using unison
what do you think?
That should be fine from UC perspective. UC needs to communicate with
alive sftp server with correct credentials. The process behind the scenes
isn't an issue
isn't an issue
Jaime Valencia
You want to test that out before rolling it into production, that's not something I've seen anyone do before, in theory, it should work.
java
if this helps, please rate
