Hold button does not work in 6900 series IP Phones
Rodrigo Damaso
Hi, all.
I have a 3925 with 15.0M IOS, CUCME 8.6 and App Load 9.1.1.0. The hold button in 6961, 6941 and 6921 does not work. I did a debug of IP Phone when I press this button and nothing appears at console.
Does anyone call help me.
8 Replies 8
Jaime Valencia
Do you have any other phone models and does it work on them?
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
paolo bevilacqua
How the ephone-dn is configured ?
kostyacroc
Try config
ephone-dn  1  dual-line
Please, see the picture.
When using routers and other CLI products, please use cut and paste, not screenshots.
Hi, Paolo. I used screenshot because I am using IPhone client this time.
Do you have some idea about the problem?
Is your ephone-template 1 applied to the ephone?
Please understand, that as an aspiring network engineer, you're supposed to use the right tools for the job.
What would you think if your doctor visits you with an MP3 player ?
