05-22-2012 11:05 PM - edited 03-16-2019 11:17 AM
Hi . Is there any CSV file generator tool available in softwaredownloads ? If it is available request someone to send the link for the same. I would like to use it for Cisco BAT configuration. Thank you
05-22-2012 11:10 PM
Hi Shalu,
When you download the bat.xlt file from the BUlk Administrator tool of CUCM, lets say you try to upload few phones with it, you fill up all the details and perform Export to BTA format, it will convert this csv files to .txt files.
You can do this with this bat.xlt files only.
Hope it helps.
Anand
Pls rate helpful posts !!
05-22-2012 11:10 PM
The 'csv generator' is an Excel spreadsheet template that you can download from the 'Bulk Administration/Upload\Download Files' menu in CCMAdmin.
Aaron
