Hold key and transfare key not work
aibrahim.sallam
Beginner
Beginner
Dears,
Kindly help me, I have a problem with all cisco phone in my company.
All of them have same problem hold key and transfare key not work when calling any external number.
11 Replies 11
Chris Deren
Hall of Fame Master Hall of Fame Master
Hall of Fame Master
What system do you have?  CME, CUCM, etc?
What phones are you using?
What PSTN connection, i.e. SIP trunk, PRI, POTS, etc?
Chris
CUCM
7965 & 7911
PRI
What is "maximum number of calls" set to on the DN?
Are the softkeys presented but dont work when you press them? Or are they grayed out?
Does it work internally?
Chris
Also, check if MTP required is checked on the Gateway as you should not need it and it may be causing you issue. If it is checked please uncheck it.
Chris
yes, the softkeys presented but dont work when I press.
yes, it is work internally
unchaked
Sorry Sir,
It's checked
Well, that is the reason it does not work. You have 2 options:
1. Add MTPs to your system
2. Uncheck it - recommended as you should not need MTP on a PRI
HTH, please rate all useful posts!
Chris
Thank you chris for your quick reply, but from few days it was working fine.
Thank you for your cooperation.
Perhaps you ran out og MTPs or they are no longer registered.  See if they show registered under media resources in CUCM.
Chris
Ok chris, let me check then I will feedback again because I left the work, and morning I will tell you.
Really I appreciated your quick reply.
Recognize Your Peers
