11-05-2019 02:46 PM
Hello all,
I have a a 2911 ISR I am using as my home router. I have recently come to possess a handful of 7962 phones. Working a day job as a LAN support team member for a large company I am somewhat familiar with Routers but not as well as switches.
I am currently a student studying and trying to learn more about these systems and want to build my own VoIP lab at home using the equipment I currently have. Spending only a few hours on the topic I have tried to figure out what is needed to run CME on my 2911 Router.
Browsing different documentation and web pages from Cisco for different offerings I have no definite answers. At the least you could say i'm a bit overwhelmed with lots of information I don't fully understand. Which is exactly why I am here on the forum seeking advice from others who may have valuable information I am lacking which would help me achieve my end goal.
Any help that can be provided will be greatly appreciated. Thank you for your time!
11-05-2019 03:20 PM
Hi @redbull88
In summary
Router
Router(config)#interface f0/0 <- to switch
Router(config-if)#no shutdown
Router(config)#interface f0/0.10
Router(config-subif)#encapsulation dot1q 10
Router(config-subif)#ip add 192.168.0.1 255.255.255.0
Router(config)#ip dhcp pool voice
Router(dhcp-config)#network 192.168.0.0 255.255.255.0
Router(dhcp-config)#default-router 192.168.0.1
Router(dhcp-config)#option 150 192.168.0.1
Router(config)#telephony-service
Router(config-telephony)#max-ephones <1-42>
Router(config-telephony)#max-dn <1-144>
Router(config-telephony)#create cnf-files
Router(config-telephony)#ip source-address <CME ip> port 2000
Router(config)#ephone-dn <1-288>
Router(config-ephone-dn)#number <telephone number>
Router(config)#ephone <1-96>
Router(config-ephone)#mac-address <phone MAC>
Router(config-ephone)#type 7962
Router(config-ephone)#button 1:1
Switch
Switch(config)#vlan 10
Switch(config)#interface f0/1 <- to router
Switch(config-if)#switchport mode trunk
Switch(config)#interface f0/2 <- to phone
Switch(config-if)#switchport mode access
Switch(config-if)#switchport access voice vlan 10
11-05-2019 04:17 PM
11-05-2019 03:57 PM
You would need to enable the UC license on the ISR, and once it has been enabled, you can refer to the CME administration guide for all the tasks related to IP Phone configuration
https://www.cisco.com/c/en/us/td/docs/routers/access/sw_activation/SA_on_ISR.html
11-05-2019 04:21 PM
