Trying to setup SIP Phones
moman62
Hello, I'm new to trying to setup SIP Phones on a cisco 2921 router that has CME 12.0 I am using Cisco CCP and get the following error messages:
SIP related configuration is missing that will enable the VoIP network to support SIP endpoints.
Configure SIP to SIP Connection and Local SIP Registrar from VOIP Settings.
Also, I will be using a SIP connection from my ITSP vendow
9 Replies 9
aakozlov85
Hi!
This error indicates that you have to enable sip registar and allow sip to sip connections first.
Connect to your router via CLI (console, telnet, ssh).
And enter commands:
conf t
Voice service voip
           allow-connections sip to sip
Sip
registrar server expires max 3600 min 3600
Bind control source-interface loopback 0         --->here you should specify your interface for media and control messages.
Bing media source-interface loopback 0
I will be using my voip phones without connecting to pc's! can I setup a voice vlan only and include the ports that I will be using? or do I need a data vlan as well?
You can just use the voice Vlan, without the need of the Data Vlan if the ports on your switch for phone only use.
g
Hope the above helps,
gsotirop
Data Vlan will not be required in this case
when I setup the vlan does it have to stipulate voice vlan?
EX:
vlan 66
name Vlan66
ip address 200.200.200.10 x.x.x0
or:
vlan 66
name Vlan66
voice vlan?
you just need to create the vlan then assign it to the interfaces and a dhcp pool in the router
Switch (config)#int range g0/1-24
Switch (config-if)#switchport voice vlan 66
George Sotiropoulos
I believe that the following link provides you the full idea of how you need to configure your CME
https://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-express/99946-cme-sip-guide.html
Make sure that the "Voice Register Global Parameters Configuration" Section is clear to you.
George
gsotirop
I did all of the above, and my 8941 phone still cannot register and now I'm getting prompted for an admin password to access the phone? what am I missing?
