03-24-2024 06:09 AM - edited 03-24-2024 06:11 AM
Could anyone advise me please, would a POTS dial-peer which receives an incoming call leg use it's destination-pattern to set the calling party (ANI) for that call?
dial-peer voice 100 pots
description Lift01
destination-pattern +44123456789$ <-- Will the lift have this CallerLineID if it places calls
huntstop
port 0/1/0
exit
I'm asking this because I need to setup a VG-400 gateway in SIP trunking mode (I normally leave this to MGCP/ccm-config, so haven't touched POTS in some time).
I could only find a vague reference to how IOS-XE handles this when a wildcard dial-pattern is matched.
Solved! Go to Solution.
03-24-2024 08:53 AM - edited 03-24-2024 08:55 AM
On a VG you would set the calling name and number with these commands.
voice-port 0/1/0
station-id name Lift01
station-id number <number you want to present>
caller-id enable !not sure if this is required, from memory I don’t think we use it on our VGs normally, this is from an example on internet
03-24-2024 08:29 AM - edited 03-24-2024 08:33 AM
No it would not use the destination pattern to set the ANI. The note you referenced is for a specific use case where there is no calling number.
voice-port 0/1/0
03-24-2024 11:29 AM
Thank you Roger, I will be testing this next week.
03-26-2024 05:07 AM
Just confirming that the station-id commands under voice-port are working in my tests.
