10-29-2015 03:00 PM - edited 03-17-2019 04:45 AM
Hi, everyone.
i hope you are well...
How can i cancel calls between extensiones with the same partition?
Regards.
Solved! Go to Solution.
10-29-2015 05:02 PM
If your question is,
CUCM have any configuration for block the calls between extensions with the same partition, other than CSS?
then the answer is NO
10-29-2015 03:08 PM
Is there for just one phone? Lets say you don’t want the receptionist to be able to call the CEO directly.
Or is for a group? Customer Service team cannot call Sales team?
Can you provide more details of your situation?
On my examples above, this will be the best solutions:
Move receptionist phone to another partition
Move Customer Service team to another partition or remove dial capability to those phones.
Rolando Valenzuela.
10-29-2015 04:24 PM
i need that the call center agents of the do not call Between Their extensions, but the extensions are on the same partition ...
Regards.
10-29-2015 04:32 PM
Luis,
I think the answer to your question is already given more or less.
so I will recap, suppose your call center agents extensions are in Partition XYZ. What you need to do for the CSS for the call agents, is to put all relevant partitions in, but leave the XYZ partition out. This will prevent the agents from calling each other.
good luck
10-29-2015 04:36 PM
Dennis is right, uses CSS and the problem is solved.
Check this link, it can help: http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-callmanager/22325-part-css-tn.html
10-29-2015 04:46 PM
thank you very much for your help, i totally understand the Partition and CSSes.
but specific question is:
CUCM have any configuration for block the calls between extensions with the same partition?
maybe my question is odd...
10-29-2015 05:02 PM
10-29-2015 03:24 PM
by assinging diffrnet css for the partition.
10-29-2015 03:34 PM
Luis, you can do it as recommended by Venperam (+5). you can simple assign different Partitions not the one which phones has in CSS (Calling Serach Space)
Example
Partitions CSS
Phone A Internal Any Partition but not Internal one
Phone B Internal same here
For more detail you can refer to below link
Br,
Nadeem
PS: Please rate all usefull post.
