How can we share screen during conference call on Cisco Jabber
ayush.shyam
Hello Everyone,
When i dial/receive a call (1 party in the call) then i have screen sharing button enabled. But when i add someone in the call, means in the conference call this button become inactive.
Can you please suggest how we can enable this, when we want to share the screen in a huge conference call.
Ayush
Switzerland
No, what I'm saying is that you need to have a video CFB to do what you're asking, if all you have are audio CFB, you cannot do this.
java
if this helps, please rate
9 Replies 9
seanvaid
Level 3
Level 3
You should be using WebEx.
https://voiceonbits.com/2015/08/28/scenario-48-desktop-share-wont-work-jabber-conference-call/
We are trying to share the screen during the internal conference call of 10 people.
That's it.
We already have WebEx but we have 8 user license. And now we are 10 people who needs to be in the conference that's why we were try to acheive same functionality in jabber.
Do you have a video conference bridge?
java
No, Only 1 to 1 is possible!
what do we need to enable it?
Actually we don't want video conference, we only need audio conference and screen sharing capability.
OK, it seems you don't understand that the screen share you're doing while on a call, is basically a video call itself, and it also consumes BW from your CAC configuration.
When you do an IM screen share, then you use RDP for that one.
IM Only Screen Sharing
In addition to the video screen share (BFCP) feature that is available to video-enabled clients when on a call, users can now screen share directly from an IM conversation when video share is not provisioned or available. IM screen sharing uses Microsoft RDP, which is a secure connection. When using IM only screen sharing, the screen share resolution and bandwidth allocations are directly managed by the underlying Windows OS.
Users can share their screens from IM with up to five other Cisco Jabber for Windows 10.5 users in a group chat.
Unlike BFCP, users do not need to be in a call to share their screen. Screen sharing is not currently supported while on the Expressway for Mobile and Remote Access.
java
so you said it's not possible to share the screen with 10 people in the audio call (conference call)?
java
Thanks for the info!
Ayush Chaudhary
Switzerland
Hi Jaime,
pretty old thread but just stuck on the same issue.
I do understand your point with Jabber running as a softphone. But we are running Jabber in CTI-Mode. Would expect that we can use the same XMPP Desktop share like in group chats during an audio conference...
Frank
