How configure Maximum Rate Bit in region setting CUCM11
oattoumani
hello
I need a help to fix an fax issue.The DN affected to the fax is configured in a callmanager
Integrated with a trunk SIP to a NativIP server. we cannot send or receiv a fax .
The fax call flow is PSTN--H323-->ISR---->CUCM----/Trunk SIP/-----NativIPFax Server.
Log from ISR voice GW
%VOICE_IEC-3-GW: SIP: Internal Error (2xx, dest sdp null): IEC=1.1.96.7.26.0 on callID 1265870 GUID=283382C8344A11E9BA91682C7BC21EF0
RTH2-GW-RNIS-3#show voice iec description 1.1.96.7.26.0
IEC Version: 1
Entity: 1 (Gateway)
Category: 96 (mandatory ie missing (96))
Subsystem: 7 (SIP)
Error: 26 (2xx, dest sdp null)
Diagnostic Code: 0
Logs from NativIP show a missmatch of maximum rate bit, the fax server send the Maximum rate bit at 9600 and the cisco callmanager send it at 14400. See details in attachment file
I need your assistance to fix in the Region configuration the Maximum rate bit of the Trunk SIP at 9600.
Thanks for your help
regards
Omar
Chris Deren
CUCM regions have nothing to do with faxing rates, you can change the fax rate to desired size at the dial-peer level with following command:
fax rate {2400 | 4800 | 7200 | 9600 | 12000 | 14400 | disable| voice}
https://www.cisco.com/c/en/us/td/docs/ios/12_2/voice/configuration/guide/fvvfax_c/vvfpeers.html
Hi Chris
Thank for your reply.
I am going to apply your suggestion and I will post the result asap.
Omar
Hello Chris
I apply the fax rate 9600 as you suggest but the issue is not resolved.
In the logs from RTMT , in the SIP call process there is an error “488 not acceptable media” between the GvoixISR and the Trunk SIP on CUCM.
Here the trace:
Message Details
SENDER: 10.172.152.9
GUID: ec325080-c7616c2e-1f9ef7-998ac0a@10.172.152.9
MSG_LABEL: 488 Not Acceptable Media
RECEIVER: [Trunk_NATIVIP] 10.172.53.117
MAC_ADDRESS: Trunk_NATIVIP
MSGTAG: 90054094
MSG_TYPE: UCM_CTRACE
CORRELATIONID: 2,100,10,1.1276356^10.188.225.4^*
TIMESTAMP: 2019/02/27 11:53:38.187
Detailed Sip Message
SIP/2.0 488 Not Acceptable Media
Via: SIP/2.0/UDP 10.172.53.117;rport;branch=z9hG4bKaXyFeQ3HcaHUr
From: < sip:53846@10.172.53.117> ;tag=QS9QDK1N1540D
To: < sip:+33155668585@10.172.152.9> ;tag=31010742~ac383807-d406-4657-81ed-184939d61707-36318821
Date: Wed, 27 Feb 2019 10:53:38 GMT
Call-ID: ec325080-c7616c2e-1f9ef7-998ac0a@10.172.152.9
CSeq: 1078617 INVITE
Allow-Events: presence, kpml
Server: Cisco-CUCM11.5
P-Asserted-Identity: < sip:+33155668585@10.172.152.9>
Remote-Party-ID: < sip:+33155668585@10.172.152.9> ;party=called;screen=yes;privacy=off
Contact: < sip:+33155668585@10.172.152.9:5060>
Content-Length: 0
If you have idea thank for your help:
Omar
